50.1 Fuser error:Low/No Fuser tempatrature, replace Fuser assembly.
For service engineers: Reason: thermo switch open, remove fuser assembly, dis-assemble up sleeve, check switch continuity, if no continuity, remove switch & just hit gently on aluminum capsule till continuity comes,make sure it should not damage or dent,once continuity comes, clean main thermister & sub thermister, fix it back, power on the printer, chek errors,adjust fuser temperature in low, give prints up to 50 blank copies, chk.. if problem repeated replace Fuser assembly, but success rate is 70% for above exercise.
Note: Only professionals can perform this activity.. Thermo switch:
