Question about Telescopes
Northstar m3 gps
Try to find the location of non volatile memory chip
0 characters
1 Points
Need to clear bushnell northstars menory
Bushnell has never given instructions on how to do this. Try calling their service center here:
Sep 05, 2010 | Bushnell NorthStar Goto 100mm 788840...
Wrong manual
Here are the Bushnell manual for Northstar:
Aug 14, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Bushnell Northstar 78-8840 Pinouts
Here is a web site with all the manuals for Bushnell telescopes -- possibly the pin outs are described in the manual for your telescope?
Apr 10, 2009 | Bushnell NorthStar 78-7880 (190 x 78.74mm)...
Bushnell Northstar GOTO 78-8850 On/Off Button
I have read the manual and they're not clear on this. The base of the telescope is what sits on the tripod. It is where you store the controller. You should find the power switch near where the controller gets stored.
I hope this helps.
Mar 26, 2009 | Bushnell Northstar 78-8850 Telescope
Celestron nexstar 8 i series alignment trouble
use the rewmote that came with the telescope and go into setup under telescope and push enter when it says calibrate motor
Nov 06, 2008 | Celestron NexStar 11 GPS (660 x 279mm)...
Manually aiming my 78-8890 telescope
NorthStar® Telescopes offer amateur astronomers state-of-the-art computer-driven location and tracking capability with simple, push-button control. With a built-in data base of 20,000 celestial objects, you simply call up your target on the hand-held control module, enter a simple "Go To" command and the NorthStar computer does the rest. Once locked on, tracking the object for prolonged viewing is automatic.
the idea is not to touch the scope but use the hand controller. so the answer is no. not recommended.
Oct 26, 2008 | Bushnell NorthStar 78-8890 (300 x 90mm)...
Aligning NorthStar For The First Time
don't know which northstar ( I presume that's the software) your using but you may find help here
Nov 12, 2007 | Bushnell 78-9669 Telescope
Telescopes Logo
42 people viewed this question
Top Telescopes Experts
Joe Lalumia aka...
Joe Lalumia aka...
Geoffrey White
Geoffrey White
kenneth njonjo
Are you a Telescope Expert? Answer questions, earn points and help others
