Question about Daewoo DTQ-20N3FC 20" TV
Television Well lately my tv has been showing a huge black box which covers the bottom of the screen everytime i try to hook up my vcr or dvd player or xbox 360 i dont know what this means and if i can fix it but if i can it would be cool to know how thanks.
  • pyradell Nov 01, 2007
    i dont really know which daewoo television i have from the list but its not the one shown its silver 20" speakers on bottom power button then av3 in the ch col menu tv/av buttons in the order left to right..hope this helps
  • sister23 Nov 18, 2007
    my dad was fiddling with the remote to his daewoo tv and now the remote will not do anything
  • 93 Answers
Ok,your problem is in close caption,get your remote control and find the the close caption button,then press.And your problem will be solve
Posted on Nov 01, 2007
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
Can't get hooked up so it ALL works vcr, converter box, dvd...
If the DVD works through this "box". Things are looking alright. There must be a number of inpus or hookups to connect VCRs or DVDs or what ever to this "box" that then allow you to hook tp the TV.
If this is the case there has to be a way to swithc the box to the different things hooked to this box so that you can see& hear them.
I do not know what this box is, but can only guess you need to get the manual or more info on how it works.
If you can try to hook each one of your pieces seperately to the box.
First unhook the DVD that works, and hook the VCR. If works, unhook the VCR and hook up the the enxt piece. That way you'll know if each of them is working.
Dec 30, 2009 | Philips Magnavox DVD/VCR Dual Player
Vcr/dvd player will not let me watch cable through it
There should be video in and video out on the dvd player. You shouldhave the wires going from video out on the cable box to video in on the vcr. Then you should have video out on the vcr going into the tv
Aug 13, 2009 | Samsung DVD-V5500 DVD Player/VCR
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Black box in middle of screen
    It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
    Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
    Flashing (ghosting) on screen when playing DVD's or VCR tapes
    I've had a similar problem, It was not the TV or the DVD player but the SCART junction box (a separate unit that automatically sent the live input to the output SCART socket, to fix I just uses a spare empty input socket.
    if you don't have one of these units try with a different SCART socket or AV input also try replacing the leads between the player and TV.
    Nov 10, 2008 | Digimate DGL32 32 in. LCD Television
    Gray box shows up on TV screen..
    make sure the subtitles are turned off on the tv and the player
    May 28, 2008 | RCA DRC8320 DVD Recorder/VCR
    Picture problem
    If you have the DVD Player connected to the vcr, it is the copy right protection software that is doing it, this is on every single DVD to defer con artist. A way to fix this, is to get a video image stabilizer, or find a way to work around the VCR. If this does not fix the problem, it is possible that the video output on the DVD Player is malfunctioning somehow
    Jan 10, 2008 | Sony DVP-NS300 DVD Player
    Daewoo DTQ-20N3FC 20" TV Logo
    78 people viewed this question
    Top Daewoo Televison & Video Experts
    Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
