Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Error message: unable to clean 46
After all it doesnt work, they said i have to reset it!!but i dont know how to reset the manual have not posted on how to reset the printer.i neeed help on how to...thanks...
  • 37 Answers
This can be resolved by a special form of reset in the engineers functions of the machine, however, it also requires the ink absorber box to be replaced. This part catches the waste ink. If this it not done you run the risk of waste ink leaking out of the machine. For that reason I cannot just post the reset information.
It is really a job for an engineer, I'm afraid.
Posted on Jun 17, 2009
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother MFC-425CN...ERROR MESSAGE READS...UNABLE TO CLEAN...TRIED EVERYTHING IN MANUAL????? WILL NOT SCAN OR PRINT...OR TEST PRINT ETC ETC...
You need to contact brother regarding that error message. It simply means that your printer's purge counter is full and you just need to RESET it to ZERO. I already have a post regarding this "unable to clean" error but it is for Brother DCP-150C. I also got it from a Brother Tech Support. So I think the commands in my previous post is different since you've got a different model. Better ask a Brother Tech Support for the procedure in resetting the purge counter.
Anyway, this is the post, if the sequence is right for your device, then this will work:
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET/OK
b. 0 then press SET/OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET/OK
b. 7 then press SET/OK
b. 3 then press SET/OK
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET/OK
b. 1 then press SET/OK (To reset unit)
a. 9 then press SET/OK
b. 9 then press SET/OK (To exit Maintenance mode)
Dec 27, 2009 | Brother MFC-425CN Multi-Function Center...
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
Trouble shooting and routine maintenance
46 means the ink absorber box is full, it only costs around $10.00 to replace but you need to get into service mode to reset the counter. I'm not allowed to give out that info...
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to clean 46
posted fix in another prob same section
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
Error Message "Unable to init 46"
error 46: waistink absorber needs replacing. you must have run quite a lot of manual cleaning cycles in case your mfc is about 1 year old....
Feb 26, 2008 | Brother MultiFunction Center MFC-440CN...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean
Hi, I tried the solution above "by obiewan" it work's for me but I do a little changes on his pattern.
1. Unplug your printer
2. press down the menu/set then plug it (just keep oh pressing it down until you see the message error 46 show up on LCD)
3. press 80
4. then look for "Purge", i think its on the 25th when you scroll down
5. then reset the pruge count to "0" by pressing 2 7 8 3
6. then press stop/exit
7. then press 9 twice
VOILA!!!
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
288 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
