Question about Creative Labs Gigaworks S750 Computer Speakers
Fuse blows after turning on control center
I have the same problem as these other people. I replace the fuse, then go to turn on the subwoofer. The subwoofer turns on fine (green light on back is on), however when I hook everything up and turn on the control center, everything immediately turns off. I go to check the fuse on the back of the sub, and it is completely fried. I have replaced at least 5 fuses, and tried multiple power sockets... still get same result. Does anyone know what is going on and can help out?!
I have a similar problem on the Gigaworks S750 system. Upon opening, I have found that the IC driving the switch mode power supply becomes basically a short, and that the transformer becomes damaged as a result there of as well. Then you have about 22 Ohms connected to your mains (after the bridge rectifier) which causes the fuse to blow. Is there anyone that can assist with a circuit diagram for this system, or of contact details as to where I can find out what the specifications of the transformer is? Can not seem to find any technical assistance in South Africa
Posted on Jun 20, 2009
  • 157 Answers
What you have there is a defected system. What you need to do is take it in and get it replaced if it's under warranty still. If it's out of warranty then you will have to buy a new system. The power converter that is in the unit has gone bad and is not doing the job that it's supposed to do.
Posted on Jun 18, 2009
New subwoofer blows fuses
you have some wires touching causing it to ground.check wiring
Dec 27, 2012 | Gemini Sound Products Gemini GVX SUB15P...
Why isn't my Logitech Z-5300 speaker system no longer turning on at all?
I have a suggestion that you can try. If the unit is no longer turning on and you're sure the electrical outlet is good (by plugging in another device) and the hand-held control panel is on, as well as the switch at the base of the subwoofer, then try replacing the fuse. The subwoofer on this model has a fuse near where the power cord enters the subwoofer. There is a slotted screwdriver slot on the fuse cover. Using a flat-head screwdriver (or your thumbnail), turn the cover about a 1/4 to a 1/2 a turn and the fuse should pop out. Keep the cover. Replace the fuse with a 4 amp, 125V (or higher) fuse that is a slow-blow fuse. There are fast blow (or fast acting) and slow blow (or slow acting) fuses. You can't replace one for the other. You should be able to find a fuse at Radio Shack. If a new fuse doesn't get your system working again, then something else is broken. Good luck.
Sep 25, 2012 | Logitech Z-5300 Computer Speakers
A few days ago the subwoofer stopped working. Yesterday I turned the system on and it wouldn't work at all. I discovered the fuse had blown. I replaced the fuse, couldn't find a slow blow fuse so had to...
Try removing the wires to the subwoofer and then hook a "aa" battery to it and see if it makes a pop sound..this will tell you if speker is ok...if it is then I think the amplifier sectionj for the sub is what is blowing the fuses...you are probably right..it looks like it's a 1 A fuse...but if it's blowing right away..it may be circuitry related
Jan 04, 2011 | Altec Lansing VS3251 Speaker
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
Fuse on subwoofer keeps blowing
Subwoofers draw a tremendous amount of power. With the amount of heat generated by amperage flow and the movement of the voice coil, you may have burned out the coil. Do a resistance check across the coil. Easy check? Temporarily attach another speaker to replace that one. Use LOW VOLUME and slowly work the vol up,and, if the fuse does not blow, it's the other speaker.
Mar 10, 2009 | Dahlquist ORBIT 5.1A System
SWA1501 Sub blows fuses when turned on...
Shorted amp or blown speaker. Other things could also cause it. But there is a short circuit in it.
Mar 08, 2009 | Mackie SWA1501 Subwoofer
Velodyne F-1800 RII Subwoofer Fuse
I am having the same problem... call Velodyne... if you have the coke can thing with the pink stuff it can't be repaired.
Dec 30, 2008 | Audio Players & Recorders
Creative Labs Gigaworks S750 Computer Speakers Logo
1,063 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
