Question about Homelite Mighty Lite Lawn Trimmer
Homelite strin trimmer head wont rotate
I have Homelite UT-20002-A. The cutting head wont rotate. Took it apart and where the flexible wire shaft plugs into engine looks fine. The flexible shaft rotates, but is somehow disconnected at the trimming head. I cant figure out how to access the bottom of the metal shaft. Can I re-attach the flexible shaft down there or is it fused at the factory? Cant tell at Homelite website. Thank you
    Scholar:
  • 81 Answers
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Posted on Jun 17, 2009
After starting a trimmer, Husqvarna 128LDX, motor runs fine, but trimmer head wont rotate with any power , or velocity.
A couple of things here, are you sure the two halves are securely together? if yes you need to check the squares of the drive shafts at both ends, these are flexible drive shafts squared into the gearbox at the bottom, and into the drive drum at the top, if they have rounded off they will slip and stop altogether if the trimmer head is loaded up.
May 25, 2018 | Husqvarna Garden
I took my homelite trimmer apart to replace the clutch, but now can not get the engine housing to go back on, is there a trick to this ? Model ut33600a
Hopefully this will help if not go to homelite.com ordreing parts then select homelite then string trimmer then find your ut 33600a
Jul 15, 2017 | Homelite Garden
Homelite y 2500 yardmachine trimmer
http://www.odref.com/homelite/string-trimmers/ut-20612r.PDF
May 22, 2014 | Homelite Garden
How do I remove the cutting head on my homelite HLT=15
http://www.ereplacementparts.com/homelite-hlt15-ut20602-string-trimmer-parts-c-18807_20299_21185.html
Here is a diagram of it. It is reverse threaded so you have to turn it like you was tightening it to loosen it. Clockwise looking at it from the bottom of the head. But there is a clutch that will let the whole thing turne. The best way is to remove the shaft from the weedeater and hold the shaft with some vice grips. Or you may be able to hold it right above the head, before the shaft tube.
Jul 12, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Need a manual for Homelite weed eater, UT 20760. It can be in PDF format. Forward to guitar0589@comcast.net. Thanks
You can download the trimmer PDF for free here - http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_trimmer_product_list.html
Jun 28, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Stihl FS45 2 cycle string trimmer. Bought in 5/06 Cutting head came off while cutting. Flexible shaft still has squared off end so it doesn't seem to be broken. What holds the cutting head shaft with the...
Dealer says shaft has broken. Stihl had a problem with some FS45's doing this. They are trying to have it repaired under warranty.
Thanks for the response.
Jun 22, 2009 | Garden
Flex shaft came loose inside aluminum curved shaft
Here's a link to the homelite parts catalog site online.
You'll need your model # to look up exploded parts diagram for your trimmer, but you should be able to get any of the parts you need there.
On the other hand, depending on your location, a local repair shop, tool rental business or even a small auto or machine shop might be happy to do the repair and order the parts for you. I'd make some inquiries first, though, as at that point a new trimmer might be cheaper...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 23, 2009 | Garden
Replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
579 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
