Question about Linksys BEFSX41 Router (DHBEFSX41)
Linksys BEFVP41 doesnt't work
I'm trying to put an "old" BEFVP41 in service, but it doesn't work. I made the following steps:
1. reset of the device (I pressed more than 30 sec on the reset button)
2. I configured my PC (XP SP2) with IP 192.168.1.100/24
-> the network interface of the PC is working properly
-> the BEFVP41 is not answering to a ping (192.168.1.1)
-> unable to connect to 192.168.1.1 with the explorer
- rhe status led is red
Can somebody help me? Thanks in advance
  • 50 Answers
1) if you can not ping the routers ip (the gateway), that means you have a firewall blocking you. disable that firewall, reboot if necessary, and try it again, now remember if disable an external firewall, like for instance Norton, that norton might enable Windows firewall, so u might have to go there and disable it as well. now also i would not hard code the ip yet on the nic, because you are confusing yourself and the situation. leave it on obtain automatic for ip and DNS. then do a winsock fix by typing this
netsh winsock reset
in the command prompt window (in the RUN field type CMD)
and then reboot. that should help. but the biggest issue that you have is the RED status. that is no good. so that could be the root of the problem, contact linksys at this number 8003267114 if you still under warranty, they would take care of the rest.
Good luck.
Posted on Jun 17, 2009
    Sergeant:
  • 173 Answers
You have to reset it.
Press reset button for 15 seconds it is in bak side of router.
then it working.
My black ink doesn't work
did you try changing the ink cartridge??? if yes then remove the black ink cartridge and then clean the copper contacts with a lint free cloth and then put it back in. if it helps well and good however if it doesnt follow the steps below.
1. Without turning off the product, disconnect the power cable from the rear of the product.
2. Press and hold down the power button for 30 sec.
3. Release the button.
4. Check if black works or not.
5. do a reset if it does not work:
Unplug the power cord from the product, and wait 20 seconds.
Press and hold # and 3 while plugging in the power cord to the product
Release the buttons after the product starts up. The product will now be reset to factory defaults.
Check if it works or not. If it does not then service the product.
Jan 11, 2013 | HP Photosmart C7180 All-In-One InkJet...
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Cannot remember log in info
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
When my pc starts I get an error message concerning something missing in the dynamic link library. How do i fix this?
Try:
Resetting the Linksys Router to Factory Default
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 08, 2010 | Linksys Wireless-G WRT54G Router
Hi there...wherever you are...i cant get my d link 625 to work..my 2 wire modem failed so i put back in my old action tec and the router wont work..plus it keeps asking me for a password and i dont...
the default password is left empty
the user name is "Admin" then press enter
If you have entered a password follow these instructions:
The following reset procedure will completely restore the default settings on your device, including your password.
Step 1: Locate the reset pinhole on the back of the unit.
Step 2: With the unit powered on, press and hold the Reset button.
Step 3: Hold the Reset button for about 10 seconds.
Step 4: Release the Reset button.
Step 5: The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6: The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for the router is admin and the password is left blank.
go here for further support for you version ( router)
May 29, 2010 | D-Link DIR-625 (790069292637) Wireless...
Linksys Group LIWRT160N Ultra RangePlus Wireless-N Broadband Router say's password is not enough characters, however I am using the right password. Why can't I set up this Window's computer?
Okay,i only option is to reset the router to its factory settings.
Please follow the steps to reset the router.
The router can be set to factory default by pressing the Reset button of the router and resetting through the router’s web-based setup page. Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. Any settings on the router will be erased and the router’s IP address will become “192.168.1.1,” the username is still blank, and the password will be “admin.”
To perform a hardware reset on your Linksys router follow the steps below.
Step 1:
Take note of the current settings of the device before resetting.
Step 2:
Press the Reset button of the router for 30 seconds.
Step 3:
If the normal reset does not work, unplug then plug back the router's power adapter while pressing the Reset button.
Step 1:
Access the router’s web-based setup page. .
NOTE: If you are using Mac to access the router’s web-based setup page,
Step 2:
When the router’s web-based setup page appears, click Administration then Factory Defaults.
Step 3:
Look for Restore Factory Defaults and select Yes.
Step 4:
May 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
Garmin 205 will not switch on
To perform a soft reset, please follow the steps below.
1.Press and hold the ?Mode? button in.
2.While holding ?Mode? press ?Lap? also.
3.Hold both ?Mode? and ?Lap? together for around 5-7 seconds.
After you have done this release the buttons and try turning the unit on. If the unit doesn?t turn on try putting it on the charger and repeat.
Sep 12, 2008 | GPS
401 Authorization Error when accessing a Web-based Utility
Getting the 401 Authorization Required error page means that you tried to access a Setup page and entered an invalid password three (3) times. To reset the password, the device must be reset to factory default settings. Resetting the device: 1. Hold in the Reset button (usually located on the front or back panel) for 30 seconds. 2. Unplug the power cord to the device and wait for 1 minute. 3. Plug the power cord back into the device. 4. This will restore the device's default settings, which includes a default password of admin. 5. You can now try to access the Setup page again. Accessing the Setup Page: Open a Web Browser (either Internet Explorer or Netscape). Type the IP Address of the device into the Address Bar and press [Enter]. 1. The User Name and Password Prompt will appear. 2. Leave the User Name Field blank. 3. Type in the Router?s Password, admin, (the default Password). 4. Click OK or press the [Enter] key. If the device was reset to factory settings, the password of admin should be valid and the Setup page should load. If not, repeat steps to reset the device.
Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
Linksys BEFSX41 Router (DHBEFSX41) Logo
616 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
