Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water is dripping from under the refrigerator, some answer is to check the collection tray and the drain tube, question is where they are? Are they underneath the refrigerator, so I need to tilt it and look at the bottom?? Bottom line is how do I execute this check? Thanks. Solon
  • solonlee341 Jun 17, 2009
    Dear Greyvesa,
    Thanks for the prompt response and solution. I still have question though, if I don't tilt the refrigerator, then how I can spot the compressor, it must be at the bottom, right? because there is nothing on the sides, the back and inside the refrigerator?? Please advise, thanks. Solon
  • mardraquessa May 11, 2010
    was the appliance newly installed?
  • 159 Answers
Do not tilt the fridge. on top of the compressor is the drip tray normally i assume the tray is full
Posted on Jun 17, 2009
  • shaun greyvensteyn Jun 17, 2009
    if you cant see at the back tilt it but not more than 65 degrease on top of the compressor is a bucket that catch the water
How do I unclog drip drain?
at the back wall inside there is normally a small depression in the molding that collects any water running down the back
in this channel there is a small hole that has a pipe running out the back to the tray on top of the compressor
the water collected in the tray is used to cool the compressor
use a small piece of wire and push it up the tube or if you have a compressor handy blow down the tube
Dec 01, 2015 | Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
WATER IS COLLECTING ON SHELVES-LOST MANUAL-DOES IT HAVE A DRIP PAN UNDERNEATH
Your defrost is working - but the drain tube is clogged. It may be debris causing the clog - but more than likely it is ice.
Access the drain tube and defroster behind the back wall of the freezer. Remove built up ice on the floor of the freezer and the drip tray under the freezer coil and defroster coil. Don't use any sharp tools! Locate the drain tube at the low point of the drip tray. Attempt to clear it of ice by using a turkey baster (or the like) filled with hot water. Direct a stream of hot water from it into the drain tube. Ice may be an inch or two thick in the tube. Once the ice is clear, water should flow easily and quickly down the tube to the drip pan under the fridge - where it will be evaporated away.
To prevent the ice from forming in the drain tube in the future, hang some metal wires (preferably copper) from the the defrost coil down into the drain tube. Make the sure the wire is long enough so that it extends at least as far into the drain tube as the ice had clogged. The metal wire conducts the heat from the defroster down into the drain tube - thus preventing ice from forming - and clogging the drain. Use copper or aluminum wire if you can - steel coat hanger wire can be used if you can't find any copper or aluminum, but it will rust. Copper electrical wire # 14, # 12 or even # 10 is ideal, but the thicker the wire is the harder it is to work - it may be easier to use 3, 4 or more pieces of the smaller # 14 gauge wire instead of 1 or two pieces of # 10.
This worked for me and will probably work for you, too. If this was helpful, please rate my answer "4 thumbs up" - thanks!
Jun 09, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Water has collected and frozen at the bottom of the freezer compartment. From time to time I get small leaks on the floor beneath.
There is a drain tube from freezer/fridge and stops under the fridge and allows water to drip into an evaporator tray. The drain tube/hose can get blocked up, it is very common. Free up the tube and you will be good to go. Sometimes just snipping on the very bottom to make a larger drain hole works too.
Feb 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Auto defrost works fine except for water accumlating in the bottom of unit under the bottom trays instead of in the water tray by the compressor. graywolf7499@yahoo.com
There is a leak or damage of the pipe leading from the evaporator downwards.The defrosted water is leaking out of the tubing to the bottom,replace this tubing or check the leak on the collecting tray under the evaporator.
Sep 30, 2010 | Whirlpool Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
it yourself.
To get to the connector assemble, you need to unscrew and
the light bulb fixture. Once you take the take the cover off (you will
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Water collects under the produce bins at the bottom and leaks out
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Oct 11, 2009 | Refrigerators
Water collecting on bottom of 13 year old fridge
All refrigerators create water when their cooling coils shed frost build-up - that water typically collects in a tray under the fridge body through a drainage tube that exits from a collection trough inside the fridge under the coil through the back of the fridge housing.
First check the tray to be sure it is not accumulating food particles which ultimately can produce molds. Clean any water from that tray first, then look for the tube exiting on the back of the fridge see whether there is any moisture at the end of the tube under the fridge and notice whether the tray has had any recent moisture. Chances are the tube is either plugged or similarly any connector through the fridge wall.
Now, be CAREFUL not to puncture the hose or the connector with a sharp instrument however the drain path must be cleared. Try blowing through the drain inside the fridge with a straw, then add a small amount of baking soda into the collection trough, adding a small amount of water to dissolve and allow this to gradually drain out normally. Only detach the outside tube if the problem has not been resolved in this manner. The tube can be replaced easy enough, the connector through the back is another question - see you parts dealer if it has been compromised.
Jul 05, 2009 | GE GSS22JEPCC / GSS22JEPWW / GSS22JEPBB...
Ice build up under rolling tray in freezer
Yes you are right there is a drain tube in the middle of the coils. You need to remove the back panel and you will see the coils of the evaporator (freezer) and right underneath you will see drain tube. Now more then likely it is plugged with ice so take some regular table salt and two or three teaspoons on the top of the tube opening will break it loose and start draining. Take some regular tap water and pour down just to flush the tube and inspect the bottom collection pan under the fridge and see how much water is coming out. Be sure to have unit turned off when you do this cause the fan will run inside the freezer compartment other wise. Hope this helps you. ken
Jan 11, 2009 | KitchenAid KTRS22EM Top Freezer...
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
