Question about Dryers
How do I determine if fuse [part # 341145] is "open"? Whirlpool dryer Model # LE6900XW0.
  • john_cochran Jun 17, 2009
    Thank you very much! I don't have a multimeter so I will dig out the heating element for a visual inspection because I think this may be my problem. I understand this is one of the parts in a dryer that can finally burn out.
  • 109 Answers
You will need a multimeter to test the fuse.
Set it to OHMS and see what reading you get.
If the reading is 0 or 0.1 or 0.2 (a low value), then the fuse is ok. Any higher and the fuse is open or as we say open circuit.
Posted on Jun 17, 2009
  • Adrian Jun 18, 2009
    No problems at all. If you get stuck, post again.
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
My whirlpool duet dryer isn't getting warm
default_avatar.gif?1349193192
Annej
Expert
AnneJ EXPERT July 03, 2012
I can understand how important it is to have your dryer working properly. However, without the model number, I can only provide some general information on the issue. There are several components that can cause a dryer to stop heating. These depend on the source of power that the dryer uses. If the dryer is electric the problem could be caused by a failed thermal fuse, hi limit thermostat, control thermostat, thermal cut-off, or heating element. This could also be cause by a blown household breaker (there are two for this type of dryer, and one can blow or pop without the other one), or a failed timer. Some of these will also cause a gas dryer to stop heating, such as the thermostats, the thermal fuse and the thermal cut-off depending on your model. However, there is also the ignitor, the burner, the safety valve, or the coils that can cause it as well. In order to determine which part is causing the problem you will need to test the different components. If you could reply with your model number and any additional details about this, I can then provide a more detailed answer.
Oct 18, 2012 | Whirlpool Dryers
I have a Whirlpool gas dryer Model LA 1580 /WO. The dryer makes a loud screeching noise. Could you determine the likely cause? Thanks, Dennis
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 27, 2010 | Whirlpool Dryers
What year was this dryer made
The date of manufacture is determined by the SERIAL NUMBER on the appliance. The following link explains how you can determine the date on Whirlpool manufactured appliances:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
Locate your serial number. It should be on a nameplate around the door opening, along with the model number.
The second DIGIT in the serial number represents the YEAR it was manufactured. The next two NUMBERS following that digit, represent the WEEK of the year it was manufactured (52 weeks in a year).
If you have questions about how to read your serial number, please post back and let me know. I hope this helps you.
Jun 08, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Tumbles but no heat - is there a fuse I can change or is it alwasy the element
Hi.
It could be a faulty element or timer/ programmer depending on model.
The thermostat/ s could also be faulty.
You really need a test meter to determine what part is faulty.
Hope this helops.
Dec 05, 2009 | Whirlpool LER5636P Electric Dryer
Do you have a routing diagram for the belt?
Go to repairclinic.com and click on the "Repair Help" link. On the following page, look for the "Dryer Belt Diagrams" link under the Special Features secction. Whirlpool is listed as either diagram H or K. If you need help in determining WHICH diagram to use, post back with your complete model number (located around the door opening) and I can tell you. I hope this helps you.
Oct 01, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer stopped working... wont turn on
Before starting troubleshooting-Unplug the dryer, because you will be removing front panel for this check.
There are several things that can cause your problem:
#1 of which is a clogged up lint trap and/or vent duct raising the heat that could cause your thermal fuse to open (blow). What to do: Make sure that duct and vent outside of wall are clear, if they were obstructed, then the thermal fuse can be checked for continuity with an ohm meter, it is located in the fan housing with 2 terminals coming off of it, if it does not have continuity (connection) between terminals, you will need to replace it, simple and less than $15 bucks.
NOTE: this problem can also be caused by a bad thermostat letting dryer get to hot which in turn blows the thermal fuse., sooo after changing thermal fuse you need to check that the temperature of air leaving dryer duct does not exceed 150 degrees, if it does replace the thermostat for less than $25 bucks, this maybe be what caused your problem in the first place. Good Luck!
Apr 28, 2009 | Whirlpool Dryers
Whirlpool gas dryer
From the sound of your problem, it appears you may have a faulty overtemp switch that gets too hot , opens the circuit to disable gas and flame, then cools down and allows it to start again.. Since you didn't provide a specific model number with your question.. use this link to find replacement whirlpool thermal fuses etc.. http://www.pcappliancerepair.com/whirlpool-dryer.php#fuse
Hope this helps..
Sep 06, 2008 | Whirlpool Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
Marvin
Marvin
