Question about Nikon D40x Digital Camera
Pictures in my d200 nikon are coming too light even outdoors
Pictures are too bright ,how do I change this?
SOURCE:
  • 37 Answers
SOURCE: P setting on D200 Nikon
  1. Set the camera on manual.
  2. Set your aperture to what ever you prefer
  3. Set the speed to 1/60
  4. Adjust your speed or aperture until you like the exposure
Program mode will do what it wants...not what you want. Sometimes it makes good choices, but you have more control in M mode.
Posted on Nov 16, 2007
  • 265 Answers
SOURCE: Nikon D200 Water Damadged
It can be repaired, but usually water-damaged cameras are either worthless or VERY expensive to repair. I should expect that yours is destroyed, since Nikon's D200 is not designed to be waterproof, and has many electronic and steel parts which are very susceptible to being destroyed by the infiltration of water. A good camera shop would give you an estimate for no charge. If they tell you that it is beyond repair, you might take it to another shop for a second opinion. Is it possible for you to claim the damage on any insurance? You might check with your insurance agent just to be sure.
Posted on Dec 19, 2007
L8MDL
  • 3 Answers
SOURCE: registering my new D200 nikon camera
Go to NikonUSA;.com, click on "Service & Support"; select "Product Registration".
Posted on Sep 11, 2008
aouate3
  • 123 Answers
SOURCE: nikon 18-200 mm vr lens not auto focusing on my nikon d200
lets start with the basics, try hard reseting it and try again, if that doesnt work then
try upgrading your firmware (if possible on your camera) and if that doesnt work then it may be the lens, but dont forget to spend a few hours trying to find a option for it in the meny
Posted on Jun 13, 2009
  • 102366 Answers
SOURCE: how do I find out how many pictures my Nikon D200
http://www.rawworkflow.com/
Sign up and get Instant JPEG From RAW. That program has a feature that purportedly reports shutter activations.
Posted on Dec 23, 2009
HELP! How do i replace the main selector button on the back of my Nikon d200? The large button that toggles picture review? My broke and I need to replace it. Thanks! Patti
Patti, replacing switches requires the outer case to be dismantled and a job for a service person. I don't know where you are in this world but the D200 is still a good camera and well worth the dollars to repair it. If it were one of mine I would send it back to Nikon or a Nikon authorized repair center.
Probably not the answer you wanted but working on these cameras isn't like changing a light bulb.
Mar 04, 2011 | Nikon D200 Body Only Digital Camera
My pictures are all washed out. If I use the
select auto,p or s or A INSTEAD OF MANUAL dial option.
Apr 28, 2010 | Nikon D200 Body Only Digital Camera
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Shutters lags for 1-2 seconds then takes picture. Nikon D200. Thanks L.C
Does it still lag with the use of the flash?
Not sure this is a camera issue because I dont know the level of expertise you have with the functions of your camera or your knowledge of photography. So no insult intended...If your in low light or indoors, try using the flash or change to a higher ISO.
Does this help?
May 10, 2009 | Nikon D200 Digital Camera With 18-135MM
Nikon D200 / photos coming out magenta somtimes blue
Set it to a manual white balance colour temperature, 5200K being an average one to start testing at. Does this make a difference? If not, then the sensor, RGB lightmetering sensor or exposure board may be at fault. The peripheral area of most sensors is used for white balance metering, which denotes a sensor issue, although if the exposure board isn't reading this information correctly, then it will give varying results. However, Nikon's 420 pixel RGB sensor on the D200 may also be taking WB readings. I'll be talking to Nikon soon, but try manual settings first.
Jun 30, 2008 | Nikon D200 Body Only Digital Camera
Black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Jun 21, 2008 | Nikon Coolpix S4 Digital Camera
Faded pictures
I had a problem with pictures not so clear, because I was in "portrait" under the custom settings menu, and it caused the resolution to be low/medium
Mar 15, 2008 | Nikon D200 Digital Camera with 18-200mm...
Digital Camera with... Problem
You should set the white balance to an appropriate setting. For outdoors, or indoors with flash, auto +-0 should be adequate. For indoor work without flash, try the incandescent (light bulb symbol) or fluorescent (strip light symbol) if you don't like the results from auto.
Nov 17, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon 5000 focus probs
Depending on how long you have had the camera - Nikon may come up with a free solution. Contact Technical Support at Nikon. The auto focus is not functioning as it should. Do make sure you are not covering any 'Windows' on the front of the camera when taking, shots.
Jul 19, 2007 | Nikon Coolpix 5000 Digital Camera
Nikon D40x Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
