Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer had about 3 codes show up
FIrst my washer had ob on there, and I thought it was that it was off balance. But it kept doing it at the 28 minute mark. THen I got ld, a couple of times. THen I got CA and it shuts off. Any suggestions on what to do?
  • jdrod75 Jun 22, 2009
    THanks! There was a clog. Everything is normal now. Yey!
  • 6,784 Answers
"Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. This is mainly a drainage obstruction or, poor pump action. I would inspect the entire drainage assembly. There may be a minor obstruction.
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip or "CI" for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 Amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 Amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector or motor controller. Overloading the unit may cause this problem.
Press STOP/CANCEL to clear the display.
Posted on Jun 22, 2009
  • Michael Masters
    Michael Masters Jun 23, 2009
    Please rate and , have a great day:)
What is 06 code on a calypso washer
could this be an OB code? if so it is an off balance code meaning the wash load is to unbalanced.open the lid redistribute the load and start it back up. all of the manuals for the calypso do not show any numbers or an 06
Nov 15, 2011 | Kenmore Elite 45986 Front Load Washer
Washer keeps shuting off in the spin cycle and the code ob shows up.
Hi
Thanks for using FixYa. Error ob indicates off balance, if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an “ob” for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load. Press STOP/CANCEL to clear the display. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer, it makes a grinding sound and the water will not drain out. it also keep boping up ob code, i have trye to balance it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%@
Dec 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer error codes
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$^@#%
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer says "ob" and there aren't any clothes in the washer
some machines can be over loaded and under loaded u need to take the clothes out and run it with nothing in if it does it again with nothing in the sensors are faulty and u need an expert to check it for u
Jul 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer OB CODE after install of nee PUMP/MOTOR combo.
Jun 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool calypso washer and it is showing an error code of C1, what does this mean and how do I fix it
CI (an "i", not a "one") and OB are related - overloaded, the washer's motor controller will draw too much current and either the average current will peak ("CA" error) or the instantaneous current will spike ("CI" error). OB - out of balance - indicates of course a load that is not balanced, or is too heavy. Wash less items and see if the problems lessen. That is what we have had to start doing, but we still can wash a BUNCH of items in this type washer!
Mar 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer machine
Off Balance. From the service manual (you can google error codes for these machines), if the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for off balance. The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow you to view and redistribute the load. Press STOP/CANCEL to clear the display.
Feb 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
170 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
