LE error message - how to finish the wash cycle?
I have a wm2077cw from LG. it is flashing the LE message. How do i get it to finish the wash cycle? i think the le message has something to do with soap...
  • 10,515 Answers
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Posted on Jun 17, 2009
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
LG WASHER WM1832CW HAS LE ERROR MESSAGE
Jan 15, 2009 | LG WM-2277HW Front Load Washer
LG washing machine Model # wm2077cw
LE is a locked motor error. If this happens often then 95% of the time this is just a bad hall sensor (motor position sensor). A technician should be able to ohm out the hall sensor to make sure. The part is relatively inexpensive and easy to replace.
This can also happen if the motor is overheating slightly from being overfilled (too many clothes) or if you do one load after the other and do not allow at least 10-15 minutes between loads for the motor to cool down. In this case the LE error will only happen occasionally.
Hope this helps, please rate my solution.
Jan 11, 2009 | Washing Machines
Our washing machine, model #WM2077CW, is flashing the error code LE. Can you perhaps fill me in on the situation?
LE means a Locked Motor Code: ( these are the manufacturers list of issues associated with that coed...)
• The connector (3-pin, male, white) in the MOTOR
HARNESS is not connected to the connector
(3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors
(3-pin, male, white) in the MOTOR HARNESS
and 4-pin, female, white connector in the MAIN PWB
ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR
ASSEMBLY and MAIN PWB ASSEMBLY is cut (open
circuited).
• The hall sensor is out of order/defective.
Oct 06, 2008 | LG Washing Machines
Wm2077cw
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Use powders for 'front loading machines'. And pl rate me if helped.
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
446 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
