Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex saltwater chlorinator not working. Checked
Intex saltwater chlorinator not working. Checked power and the transformer/power supply is not providing juice to the motor (maybe got too hot down here in texas). Trying to get a new transformer to replace it. Could not find on intex website. Ideas???
    New Friend:
Mine did the same 3 yrs old. Decided to tear it apart to get txfo info:
Manufacturer logo is a square in a square
name plate info:
input 110 to 120vac, 60hz / output 16.5vac at 11amps + 10vac at 0.5amps
Behind the epoxy the txfo has a printed circuit board and behind it has a blown fuse which I replaced and worked well
Posted on May 29, 2013
  • Mike Aug 28, 2013
    How did you get the epoxy out? I have two transformers which I beleave have blown fuses, would love to get them working..
I had one for 3 years and it blew the transformer. I just bought one last year and it just died the other dat. same thing transformer. Either I have bad luck or else the transformers are garbage.
Posted on Aug 25, 2012
  • 4 Answers
IF YOU HAVEN'T HAD IT A YEAR , RETURN IT TO INTEX FOR REPAIR
Posted on Jul 19, 2009
Why does my new intex saltwater system keep alarming low pump flow even after i connected a new filter pump, checked the flow sensor and cleaned the titanium
are your filters clean? try running without cartridges if it still errors out sounds like something is caught in the pump impeller
May 09, 2014 | Intex Krystal Clear Saltwater System Pool...
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Why would our salt water system not be producing chlorine? Intex it was installed less than a month ago. to a very green pool we have put in chemicals and gotten it pretty well cleaned but its still is...
first crack union at return see if chlorine present with test strip if ok then pool needs super chlorination its eating up your chlorine if no chlorine at return have salt level checked if ok check sensor and cell if unit is working must keep balanced unit will only maintain
Dec 25, 2017 | Intex Automatic Salt Water System for ...
Power shuts down
Sounds like a power supply issue.
If you call intex and tell they you have a power supply problem and a reciept within two years. they should ship you a new one.
Jun 23, 2010 | Intex '10 Saltwater System Pool...
System shuts off and will not chlorinate
check or replace sensor and check cell if ok possible bad transformer
Jun 20, 2017 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator not producting chlorine
You can test if the 8110 is generating any chlorine by taking a water sample directly at the pool return. You can invert your container so it stays filled with air until you have it positioned in front of your return. Make sure your test chemicals are not expired and test the sample. You should get a high reading if the 8110 is producing any chlorine. If it is producing chlorine, you may want to make sure you have the correct level of Cyanuric Acid. In my pool, if the Cyanuric Acid level is low, the chlorine level drops to zero quite quickly.
If the sample indicated your 8110 is not producing any chlorine, I would check to see if you have approx. 24V DC between B+ and Gnd on the screw terminal strip on the main circuit board. The transformer supplies two voltages to the 8110. One voltage powers the electronics and the other powers the electrolytic circuit. So it is possible for part of the unit to work if one voltage has failed.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
4,157 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
