Faulty spindle motor in Rotel RCD-930ax CD player
The spindle motor in the cd player is not functioning properly. It won't even spin when a CD is inserted, just give forth noise. I tried to turn the shaft with my finger about 90deg, then it worked, and the disc directory could be read. The next time I inserted a disc again, the same problem happened. Also, it will suddenly stop in the middle of playing a song, displaying 'No disc'.
Is the motor brushless? Can you recommend a similar replacement of spindle motor for the model since the original is no longer produced? Otherwise, please advise other way to get around the problem.
Thank you very much.
  • 99 Answers
SOURCE: Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Posted on Sep 01, 2012
Kimi
  • 277 Answers
SOURCE: won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Posted on Dec 04, 2005
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
  • 77 Answers
SOURCE: CD Player doesn't work; says "disc"
i would say that your lense is dirty and yes cleaning it might help
Posted on Feb 11, 2008
SOURCE: Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Posted on Mar 04, 2008
I have a rotel rcd-1520, cd player. It hasn't been used much. It won't register that there is a CD, when I load the CD into the player. Any idea why?
the beam on the electronic eye might not be reading the disc...clean it as much as you can it might help...good luck to you
Aug 25, 2013 | Audio Players & Recorders
Dvd not spinning properly
I had the exact same problem.
There was a bad batch of spindle motors (why they didn't use brushless is any body's guess). I replaced mine and it is quite easy. I even soldered in the single-DVD player's (same basic model number, just not multi-disk) motor because I couldn't find the right part for the multi-disk model (or the single was cheaper, I forget). That was years ago and it still works great today (I didn't like the lack of features on a cheap replacement player).
Apr 08, 2008 | Sony DVP-NC675P Multi-disc DVD Player
My Craig ESP 60S Portable CD Player won't work. It starts spinning then stops. I have tried mode and program, but nothing helps. This is my second Craig CD player to do this.
sounds like it has a faulty laser and it wont read so the player stops the cd spin motor. try cleaning it and see if it works
Good Luck!
May 11, 2011 | Craig Personal CD Player
Philips AZ2025 say "no disc". CD turns really slow.
Try getting the lens cleaned with a Cd cleaner and see if that works. If that doesnt even spin then the Spindle Motor that spins the disk has become faulty and needs changing.
Mar 20, 2010 | Philips AZ2025 Cassette/CD Boombox
Cd drive does not spin after tray door closes
you may have a faulty spindle motor or a faulty/dirty laser unit which is not feeding information to the drive IC hence not spinning. hope this helps?
Sep 13, 2009 | Audio Players & Recorders
I AM HAVING ERROR EACH TIME I TRY TO PLAY A CD.
When your CD does not read any disk, and returns error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, or a faulty spindle motor unit.
If it is a lens problem, then you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , the unit will start losing the rest of functions, and ends up not reading anything at all, and returning error.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player , and clean lens directly with q tips and isopropyl alcohol, or to replace the lens, or the whole drive unit.
Sep 04, 2009 | Technics SL-MC50 CD Player
Cd player on boombox not spinning properly.
Might be the laser but try lubbing the spindle motor 1st!
Mar 02, 2009 | Coby CX-CD248 Radio/Cassette/CD Boombox
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
NAD C521 discs not spinning
The CD player has a sensor that is supposed to detect when a disc is inserted and spin it up etc. yours might be the problem, either it has some loose connections (that you haven't noticed) or it simply misbehaves. Another thing could be the motor itself that somehow 'misses' the spin up signal and needs a 'manual' boost. The best solution in your case is probably to bring it to some lab.
Sep 14, 2005 | NAD C521 CD Player
476 people viewed this question
 Grubhead
Grubhead
