Question about Koss KS4110 DVD Player
DVD won't open and has DVD inside
It doesn't work with remote or manually. How do I get it open, and has this player reached the end of the road?
  • catherinebei Jun 18, 2009
    Thanks for hte input. I ended up unpluging it and gently banged it a couple of times. I then plugged it back in and so how managed to dislodge the DVD and the door opened. I put in another DVD and have had no further problems.
  • 32 Answers
Most likly the cd jammed the tray shut or the motor is gone simply undo the screws on the side and the back take the cover of (MAKE SURE IT IS UNPLUGGED) u should be able to get the dvd out from there just look around make sure nothing is blocking it that you coulndt see from the front
Posted on Jun 17, 2009
Remote stopped functioning for dvd\vcr unit
When the remote control won't operate the DVD player recorder, check the batteries. Try replacing them and see if the remote works. If the batteries are fine, the code on the remote and the code on the DVD player recorder might not be the same. When aiming the remote at the unit a number will be displayed. To set the remote to the same number, which will be 1, 2, or 3, press down OK on the remote as the appropriate number at same time.
God bless you
Sep 27, 2012 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
DVD player not working.
Hello
The changer mechanism should be suspected. It is a skilled work to look into. You have to disassemble it. There are three microswitches inside the mechanism, which give signals of the state of the mechanism to main system control IC. If the loading gear wheels have some problem, these witches won't engage well, and the the whole mechanism will be inoperative.
Mar 04, 2012 | Panasonic Televison & Video
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
How do I open and close my dvd player using the remote control
This Model doesn't have an Eject Function on the Remote Control.
They work on the principal that if you're changing the DVD then you'll be by the Player anyway to use that Eject Button.
Jun 03, 2011 | Sony DVP-SR500H DVD Player
Remote does not work unless I am in the garage. Outside the door it will not work.
hello emar... check to be sure that the little wire antenna is hanging down from the back of the garage door opener motor. Then check it. If it still won't work from outside, install new batteries.
If that doesn't do it, remove the new batteries and use the eraser end of a common pencil to clean the battery contacts inside the remote. then reinstall the new batteries and try it again.
May 04, 2011 | liftmaster 83lm Billion Code 3-button...
I need the universal code for my bush dvd player?
TRY THIS. It works on my Philips DVD player: To make some DVD players play disks from different regions. 1. Connect DVD to TV ensuring both are then switched on. 2. Press "OPEN/CLOSE" button on DVD player. 3. Enter "8421" using remote control. 4. While watching TV screen repeatedly press "Select" on remote control until region 9 is reached.  5. Press "OPEN/CLOSE".
Dec 18, 2008 | Televison & Video
About a thomson dth 8555x probleme
my thompson dvd decoder player doesn't play any disk...
it complain disc error
please help me out...
Feb 05, 2008 | Thomson DTH7500U DVD Player / HDD Recorder
Koss KS4110 DVD Player Logo
189 people viewed this question
Top Koss Televison & Video Experts
Marvin
Marvin
richochet
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
