Question about HP Pavilion dv2000t Notebook
Baby puked on keyboard.. lights up but no screen display
So my son puked all over my keyboard and ruined it ovbiously. but i turned it on today and all the lights light up and i herd the fan go off but the screen is black like if it was off.. can any1 help me so i dont over pay for the fix?
  • thegoshem
    thegoshem May 11, 2010
    As with all electronics its best not to turn them on if they get wet. Immediately turn the device off, remove the battery and let it sit and dry out.
    You should let it sit out for longer without the battery just in case it is still wet. If the audio was on when you were last using it, can you hear it booting into windows?
    Unfortunately laptop motherboards generally lie directly under the keyboard. If the keyboard gets wet and so does the board, you can fry it. If it does not fry and you do not get it dry immediately and leave it to dry for many days (and even if you do) you can get corrosion on the metallic parts which will cause it not to work. Depending on how old the laptop is, you are looking at anywhere from 80-200 dollars for a motherboard and then the cost for someone to install it. Some places charge around 100 dollars. Then i would of course suggest a new keyboard which will run you anywhere from 20-70 dollars.
    Even if only the gpu was damaged, most boards have it built in now which means replacing the entire thing.
    If the laptop was cheap, you may want to consider just buying a new one.
    Take it to a friend to take a part to have a look at it. Be prepared to pay for someone to take it apart to tell you its going to cost some money to fix (especially if there is still puke on it (yuck))
  • Steve Sweetleaf
    Steve Sweetleaf May 11, 2010
    was it just the key board he puked on.lol shouldnt affect your brain unhook key board see if pc fires up.if so replace board
    President:
  • HP Master
  • 1,996 Answers
Links here, here, here, etc.
Service manual here, Keypad instruction here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 17, 2009
    Sergeant:
  • 173 Answers
First when you power up your lapto press F8 key thenennter in enable vga mode.
Then change screen resolution to 1024*768
Tehn aply and okay.
Acer aspire has power, fans turn on and run non stop, but all I have is a blank screen and no keyboard function. Any advice is helpful
plug into external display with HDMI cable see it you can see the desktop. If you do it is time for a new screen/power supply is good
Mar 04, 2015 | Acer Computers & Internet
Yamaha dgx-640 display
There is a small turning button on the back of the keyboard to change the screen tone and brightness,happend to me and this fixed it,i thought mine was broken too,till i spotted it
Oct 21, 2012 | Yamaha DGX 640 Keyboard Arranger
When I turned on my laptop today the screen did not turn on. The green light is on, on the keyboard so looks like the computer is on but there is nothing on the screen. Any suggestions
try to do a power drain by removing the battery and anything connected to it..> press power button for 1minute > plug back in the charger and after few secs try to turn it on...
May 12, 2011 | Toshiba Satellite L500 Series Notebook
I need to change a battery in a baby g watch
mcdevito75 here, Casio watch with the LCD display, any wrong pressure on this display and your Casio is ruined, the liquid display can break very easily. BEST BET, look for a small watch repair shop in your area for this battery change.
Jul 14, 2010 | Casio Baby-G Wristwatch
No Display/Beeps - TOSHIBA Satellite M115-S1061
There's nothing much you can do at this stage apart from get another keyboard with a function key and try to switch screens, other than that you could check the inverter board & connections there.
Remove the screen bezel, At the bottom of the screen you will see an elongated piece of circuit board with wires coming from either end covered by frosted plastic.
That is the inverter, check the connections on the inverter (both sides) and power the laptop up to check the display, to remove it gently pull the plugs from each end and remove the screw from the middle and pull the board away.
Look on the back of the inverter itself for a copper coil, if you re-solder the solder points around the coil you may find it works again as components that suffer from extreme heat the solder joints dry causing bad connections, re-floating the solder solves the problem in 90% of cases.
Good luck.
Sep 10, 2009 | Computers & Internet
Have plugged a MS USB wireless keyboard and mouse into USB port on baby - to use big screen and keyboard. It works well, but when I unplug USB keyboard, the baby's own keyboard won't work properly ie when...
Hello, your numlock keys are ON, find your Num Lock button and press it off.
It can be a 2 button combination like FN(function button) + Num Lock button. Then it should work.
other way is to press numlock on your external keyboard and then disconnect the board. see if it works.
Jun 26, 2009 | Advent 4211c Notebook
LCD Display on HP C5180 printer stopped working.
sorry but the display is probably still covered in puke inside. you will need to replace the whole display. or take it apart and clean it check that everything is ok and put it back in.
Nov 21, 2008 | Olympus P 400 Thermal Printer
HP Pavilion dv2000t Notebook Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
