Question about 2wire 2700HG-B Router (2700HGB)
Where or how i can edit my router settings? - 2wire 2700HG-B Router (2700HGB)
    Sergeant:
  • 173 Answers
For edit your router settings
-> first connect your oruter with ethernet cable to computer.
-> then clik on following link
For LInksys Dlink and other router defaults access link is:
http://192.168.1.1
or
http://192.168.0.1
for belikin router
http://192.168.15.1
then enter your ername as "admin" and password is "admin" or blank or "password"
then you can edit your router settings.
Posted on Jun 17, 2009
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
HOW TO SET PASSWORD ON D-LINK DIR 300
You can set both network and administrator password using the set up wizzard.
Note to set network password choose WEp (or preferably WPA) encription.
Mar 02, 2011 | D-Link DIR-300 Wireless Router
I installed a new Netgear wireless router. My old G router didn't cover the whole house, so I got a N600 N/G router. My Acer 5610 hooked up the the old router with 128 bit WEP encryption fine, as did my...
This could be a few things. all are simple settings.
If you can see other computers but can't get out, your acer needs the gateway ip number. If you are running DHCP this should be automatically set but you can also manually edit the IPV4 settings
TCP/IP and add the gateway as well as the other settings. The gateway is the ip# of your router that is connected to the cable modem or the dsl modem.
As long as you don't have the number range set you can fairly safely add any number in the allowable range. So you could edit the tcp/ip settings with something like the following:
adress: 192.168.2.25
netmask: 255.255.255.0
gateway: 192.168.2.1 ** insert actual addy of router.
DNS servers can be found on your isp's info page. You can use any dns server that will let you connect. Without the dns you won't get out on the net either unless supplied by DHCP.
Jul 30, 2010 | Acer Aspire 5610-4648 Notebook
I need to make my bilken 54 router secure
look on the bottom of the router there is a stricker with a website, go to it enter the username and password found on the sticker. Once in you should be able to edit your security settings
Feb 23, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I can't hook up my PC with my wireless router how I can do this?
You could simply hardwire your computer directly to your router, unless you want to purchase a Wireless Card or USB. You will still need a computer connected to your Wireless router to act as a terminal to edit and set the settings on the router. Most regular routers use CAT5 (Ethernet) cord to setup their networks, which is what you should use.
Go to your local store and purchase 2 CAT5 Cables to connect one from your modem into your router and one from your router to your PC. Once you have set up your wireless router you can then access your router from anywhere in your house.
Good luck, if you need help feel free to comment.
Thanks,
Brandonmxb
Dec 14, 2009 | Linksys WRT160N Wireless Router
Access routers configuration and wireless filter to edit MAC List to add MAC adress
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then check wireless or wi fi settings you find there MAC filtering or mac security edit that list then save and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 10, 2009 | Computers & Internet
Wireless hookup (Roku player) to DSL 2WIRE 1701 HG Gateway
make sure to configure the wireless settings of your roku player matching the wireless settings of your router. You need to do manually, go to the network settings of your roku, go to wlan settings and edit the SSID and wireless security key
Jun 28, 2009 | 2wire (1000-400108-001) Router
Netgear router setup
also, I am pretty sure you have to be PHYSICALLY connected to the router, not using wireless, if you want to edit the settings.
Hope this helps...
Sep 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
HOW DO i UNDO THE SECURITY SETTIMG ON MY LINKSYS WRT54G? WIFE CAN NOT GET ON LINE WIH THE SECURITY SETTING.
all you have to do is to reset the router for 10 secs. to set the modem to its factory default settings. after that you need to access the configuration page of your modem and start in the beginning---configure the router again.. if u will edit the settings only there is a possibility that the changes will not take effect.. so better reset the modem...
Mar 23, 2008 | Linksys Wireless-G WRT54G Router
Nintendo Wi-fi Connector Problem
nintendo ds should work with most routers it's just the set thats a problem, once the wifi game is in go to wifi connection one settings,then where it says auto obtain ip address click no, then edit,then use an ip address that is the next digit up from your pc or your router eg, if your routers ip address is 192.168.2.1( this is what you would type in your internet browser to get into the router settings), the next digit used by a pc would be 192.168.2.2, so use 192.168.2.3 or above incase you have more than one pc. Next is the subnet mask which should again be as the routers subnet mask which will more than likely be 255.255.255.0., press edit and enter that number Next is the gateway setting, press edit, this is the same number of your routers own ip address as mentioned earlier this is the ip address you type to get into the router eg 192.168.2.1. next is auto obtain DNS, again click no, then on the primary address click edit and again enter your routers own ip address. next is secondary DNS, again click edit and again enter your routers ip address, then click save settings. You should now be able to connect to your router and the wifi connection at nintendo server.
Jun 30, 2007 | AOpen AOR-401M Router
2wire 2700HG-B Router (2700HGB) Logo
2,006 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
