Brother IntelliFAX 4100 Laser Fax Logo
A
Anonymous Posted on Apr 08, 2014
I changed the cartridge, now we can't send faxes
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Lexmark 4200
You dont need to have the cartridges in the printer when sending fax but you should have the cartridges installed when you recieve faxes.
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Changed cartridge on fax and keeps saying install new cartridge will not let us do anything else
sir,
can u send the fax machine model number so that i can forward any solution for that.my mail address is [email protected]
Fax not printing
Where can I find the solution?
Can't recieve or fax records
Check for bent contact pins that rest against the cartridge.
2answers
Cannot receive faxes or do copies
If you still have your old cartridge reinstall it that will tell you if it is the cartridge or not. If you still have the problem,it could be the encoder.
Norman Weimar
Norman Weimar
k24674
