Question about Refrigerators
Fridge won't stay cold and freeze is not freezing
I can't seem to get the temps to stay where they need to be they both (fridge & freezer) are in the 60 degrees area and I'm not sure what the problem could be?
  • 159 Answers
Low gas level in the system
Posted on Jun 17, 2009
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
The refrigerator and the freezer are staying too cold. The temp controls are at the lowest possible and still things in fridge freeze. I can hear the compressor cycle of for a while then on for a while....
things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help out.....
Jun 09, 2011 | Refrigerators
Food keeps freezing in my fridge. Even at the lowest temp.
in the fridge compartment check behind the control panel where the light bulbs are remove this cover and make sure the damper vent door opens and closes when adjusted with the fridge control sometimes they ice up from condensation and freeze in one position and this may let too much cold air in from the freezer for too long,otherwise it also could be a defective electronic control board in this same area
May 13, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Too cold
If the unit seems to be running non stop, you may have a bad cold temp control. If you have ice cream in freezer, it will likely be rock hard, that you need a chisel to scoop. if your ice cream is ok, its likely not the temp control. On your GE, in the fresh food section, do you have a canopy on the ceiling of fridge, and likely covers the whole top back portion of your fridge? If you do, there is a damper door inside, that breaks off its hinge, and stays wide open, allowing cold air from freezer to constantly be pulled into fridge, freezing food. If you do have this canopy, it will need to be replaced, as you cannot reattach the damper to its hinge.
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Maytag fridge which freezes food in fridge compartment
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 21, 2009 | Maytag MFI2569VE Bottom Freezer French...
Fridge section freezes
I would need a model number to even try. Several different ones will probably work.
There are other reasons for the fridge to freeze. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Does the compressor ever cut off? How about when you turn the freezer temp control to the warmer side.
Aug 18, 2009 | Refrigerators
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
Refrigerators Logo
300 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
