Question about Ricoh Aficio CL7000 Laser Printer
CL7000 Replace fuser unit type G error
My copier said replaced fuser oil after being low. So I finally did but the message won't go away. Please solve this
Run SP7-804-9
If you don't know how, or what that is, then you'd better call a service depot.
I will not post or discuss service mode procedures with end users, because you can create a great deal of problems if you're unsure what you are doing. (No offence)
Posted on Jun 17, 2009
Part number for fuser oil for aficioCL7000
Ricoh Aficio CL7000 Fuser Oil Maintenance Kit - Type 7000G
OEM Part #: 400878
Sep 19, 2013 | Ricoh Aficio CL7000 Laser Printer
How do you refill fuser oil on a aficio CL7000? and where do i find it to replace it?
It is a fuser oil cartridge. When you replace it the counter gets reset automatically. It is located on top of the fuser unit. This is the part that gets hot and is located right where the paper exits the printer. It is accessed from the left side upper doors. Here is a link to a site that sells the unit as well as all the parts and supplies for your printer. The top picture on this link is the fuser oil cartridge so you can see what it looks like which will assist you in locating the unit in your printer.
Installation instructions are included in the box with the new oil cartridge.
http://www.precisionroller.com/search.php?q=cl7000+fuser+oil
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 28, 2011 | Ricoh Aficio CL7000 Laser Printer
How to refill oil Fuser at unit at Ricoh Aficio 2232c/2238c
These machines use oil supply units located on top of the fuser unit. They are not refillable order another and replace... continueing to run this machine without fuser oil will cause the fuser to fail and copies to look terrible
Dec 17, 2009 | Ricoh Aficio CL7000 Laser Printer
Aficio 2232C, I cann't do anything.
Looks like you need to replace your fuser oil unit (the oil is used to lightly coat the fuser to prevent paper sticking). This is just a simple part swap out, not much harder than loading the printer with paper, full instructions are in the manual (see link) and a the units themself are readily available, if you dont know your local supplier google will return dozens of online merchants
http://ricoh-usa.com/downloads/manuals/bw/aficio2232c.pdf
Sep 30, 2009 | Ricoh Aficio CL7000 Laser Printer
How do I top up the fuser oil on a Ricoh CL7000 printer does not seem to be anything in the maintenance manual
You don't. The Type 7000G Maintenence Kit is the self contained oiler unit, rated for approximately 30,000 prints on 8 1/2" x 11" stock. If a person were to try to "top off" the oil, where would said person locate the correct type of fuser oil. Not all fuser oil is the same, viscousity wise as well as chemical composition. What an expensive mess.
Sep 11, 2009 | Ricoh Aficio CL7000 Laser Printer
HP 8150DN I got 50.1 Error message so I replace low voltage power supply and know I get 51.1 error message now
Yes, 50.1 refers to the fuser, and that is very easily replaceable. (no tools) However, in the 8100, you have a 75% chance that it is indeed the low volt power supply. The low volt power supply powers the fuser.
As a service approach, I always replace the fuser first because it is so easy to do and we always have them in stock.
If that does NOT clear the error, then we KNOW it is the low volt power supply. That is a very straightforward repair.
Mar 04, 2009 | HP LaserJet 8100n Printer
Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL7000
You NEED to REPLACE the black development unit with a BRAND NEW item......these things are chipped so it won't accept previously installed units.If the problem still exists try a new PCU (toner cartridge).
Apr 04, 2008 | Ricoh Aficio CL7000 Laser Printer
Error message
That means you have to replace the 3 color drum units
in the front of the printer. NOT the fuser cartriges but the roller
units.
Mar 12, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh CL7100
THe oil unit is not entered correctly
Feb 22, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio CL7000 Laser Printer Logo
419 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
