I have a Toshiba A135-S4527.If I have the charger plugged in the computer will turn back on by itself after shutting it down. Works fine if it is unplugged. Toshiba support was of no help with this.
  • Anonymous Mar 30, 2014
    it is plugged in and when i turn it on it shuts itself back off
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
You AC adapter is going bad and thats whats causing you to have this problem
Posted on Jun 17, 2009
Toshiba A135-S4527 starts to power up then shuts down.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 08, 2012 | Toshiba Satellite A135-S4527 Notebook
Plugged in, not charging toshiba
Turn off computer, take out charger, then try taking the battery out of the laptop (located at the bottom of the laptop) or side then re-insert and turn on laptop and plug charger back in. Hope this works! if not you either need a new charger or new battery, I suggest u find someone with a toshiba charger to test if it is a problem with the charger or your battery! keep me posted! and good luck
Feb 02, 2010 | Toshiba Satellite A135-S4527 Notebook
My toshiba s\atelite a135-s4527 wont turn on and
Could be the "resume" battery that has died - its an internal battery shrink wrapped in bright green plastic on tosh's normally - you might be able to get to it by unplugging stuff, battery, cd rom etc etc....unplug it and plug it back in again, if it comes alive again order another. I went on a toshiba laptop maintenance course years ago with a company that i worked for and that error that youre seeing was the fix....see if that works...
Aug 07, 2009 | Computers & Internet
Toshiba Satellite A135-S4527 WILL NOT POWER UP. WHAT COULD CAUSE THIS PROBLEM?
check the charger if working or not, remove the batery then turn on your laptop.. if the same problem check the dc jack connector... or chips
Jul 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
Have you left a cd in drive? It could be trying to read a disk to boot from if thats how your boot order is set up. This is the first simplest thing to check.
Char S
May 24, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba laptop satellite A135 S4527 power
take it with you when you go and try the new cord before you buy it , Toshiba's are Notorious for the charger cords to be crappy and also the port for the laptop itself to break and need repairing , witch you have to send it to toshiba to get done if that is the case
Apr 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba A135-S4527 will not automatically shut down
If you truly believe the problem happened right after installing the new mouse, then you should start by uninstalling the software for it. Go to Control Panel -> Software -> Uninstall. If this fails, you can use the System Restore utility to rollback the Windows registry to a time before you first installed the new mouse software. Have you tried to unplug the mouse and not use it, atleast on the attempted shutdown process?
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4527 Charger problem
Get another laptop.
The A135 is a lemon.
Problem is either with the dc jack on the board or more than likely the motherboard is damaged.
I've repaired a number of A135's and 95% of the time motherboard had to be replaced.
Sorry for the bad news, but I hope this helps.
Mar 02, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba's A135-S4527 Battery isn't working anymore
Have the battery checked or better yet, replaced. Prolonged use might damage the charging circuitry of your machine.
Jan 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
Alun Cox
David Payne
David Payne
