Question about HP Compaq Presario V6000T Notebook
Ports of my laptop v6000 are not working and there is some linings are coming...pls solve my problem
  • thegoshem
    thegoshem May 11, 2010
    What ports are not working?
    What do you mean "there is some linings are coming" ?
  • 85 Answers
Install Windows Xp O.S.
if consists, re install your bios data from hp compaq web site.
Posted on Jun 17, 2009
My laptop compaq presario v6000 does not switch on but the power light comes on when the chager is on. when i try to turn the computer on it just flick the light on then back off. can anyone yep me to
The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50.
http://www.chargerbuy.com/original-compaq-presario-v6000-ac-adapter-65w.html
Dec 16, 2012 | Computers & Internet
My base doesn't light up the power display and sound display at the bottom. The power button works; however, the volume buttons do not. I also have hooked the dock up to a 2 port USB KVM switch and it...
what OS, what operating system.
KVM are very unreliable. , we could talk KVM for days, on this.
no KVM evens stated, brand or model number.
dock ,circa 2008, compatible with V6000
what OS on v6000.
we can not guess what OS you are running, at all.
its a USB problem with the KVM.
V6000 is a 2006 product..
that came with XP or VISA, neither are supported now.
the V6000 must have all its HP drivers installed to work right.
no KVM is guaranteed to work here, with XP its real bad.
XP has bad USB drivers, that are infamous for not working
with odd USB devices, nor many other things,
got SP3 for XP, IF XP>? it fixes some of that be never all.
this is a V6000 to KVM USB issue.
and no OS stated at all.
May 23, 2017 | HP xb3000 (417329-001) Docking Station
Compaq presario v6000. no problems when closing next time I oppened it I got some horrizontal lines on the screen then it went black and now can get nothing. All the lights are working but cant get any...
There is a hardware problem with the laptop that is why the screen is black. Take a good look at the screen with light reflected on it, to see if it looks in any way damaged or have some kind of ink on the screen, if you do not see any of the two, then it simply means the module of the laptop is faulty.
The module acts like a flex on the laptop, if the laptoo hits a hard object or falls or have a heavey load placed on it, then, the module can develop some fault.
First, it starts to flicker, then it shows some horizontal lines, then it goes blank once in a while, sometimes it remains stable, and later on, the screen does not come on at all while other parts remain functional.
Try to have a repairman replace the module of the laptop and it will be in good condition once again.
For the main time, you can use a external monitor or a lcd television. To use this, check your lcd television if it has the RGB(PC) port at the back, then you get the cable that connects a CPU to the monitor, and connect it into the printer port on the laptop and connect to the RGB(PC) on the lcd television.
After connecting, your television will serve as the screen. And you will enjoy your laptop from the lcd.
Take care and good luck.
Oct 25, 2010 | HP Computers & Internet
I have Compaq V6000 series laptop with AMD Processor & nvidia graphic card ,my laptop?s lower half of screen becomes blurred & will become ok after some adjustments & again become blurred when...
There was a TSB about the motherboards on the V series describing severe video issues and Nvidia GPU failures. Many consumers got a motherboard replacement. Try using a laptop cooler in the meantime and see if that helps a little. Also try googling V6000 video and see how many others got nuked by this poor design.
Mar 13, 2010 | Computers & Internet
My presario v6000 laptop will not start the lights come on but screen stays black and then it keeps turning off and on lights only
Good morning! probably there's a problem on the power supply line of your laptop. kindly bring the unit to authorized service center of presario. best regards.
May 02, 2009 | Computers & Internet
Need audio driver of compaq presario V6000
Here's a link to the audio drivers for the V6000. You will need to download both that are listed under audio.Don't forget to rate me (fixya). thanks
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=1842078&lang=en
Jul 31, 2008 | HP Compaq Presario V6000T Notebook
How to add freon in 2002 Ford Tarus? Where is the low pressure port loacated"
hi bighobo,
first, locate the bigger hose that comes out of your compressor that goes to your firewall towards the evaporator, that is the suction hose. look for some fittings that comes out of that pipe and covered by a plastic cap. that is the pressure port where you can add freon.
i hope i solve your problem..
tnx pls rate me
drcool299
Jul 19, 2008 | 2002 Ford Explorer Sport
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
HP Compaq Presario V6000T Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
