CD player can't play recorded audio cd's
I have a CD Alarm Clock Radio Audiovox CD1167 but can't play recorded audio cd's, only play original audio cd's
  • Anonymous Mar 17, 2014
    How do I set the alarm on the digital clock with the cd player. How do I set it for the morning, not the p.m.?
  • Anonymous Mar 26, 2014
    will not allow any cd to play but radio plays perfect
  • 341 Answers
That sounds right, some of your cd players will not be able to play recorded cd's . It's lame, but that's the way it is. Sorry.
Posted on Jun 17, 2009
How do you put a cd in
Kylie, if there is a CD tray press the eject button and put CD in tray, push tray in easy to load. If no CD tray insert CD into CD slot and push gently to load. Some have a lid on top that you simply open with your finger then load CD. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JCR 310 AM FM Stereo Dual Alarm Clock Radio with CD Player
Christmas Presents 2013 RCA RP5605 AM FM CD Clock Radio
Magnavox alarm clock radio CD player
Problems With My GE General Electric 7 4901A CD Player AM FM Clock Radio
Jun 17, 2016 | Audio Players & Recorders
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 | Watches
For the Trutech cd clock radio (cd1189) I am attempting to get it to play a particular cd track as an alarm. Is this possible, or can I only play the first track?
I think it will only play the first track.
You can "rip" the original CD and then "burn" the track you want to a blank CD as track 1. I believe this is the only way possible.
Apr 13, 2011 | TruTech Clock Radio
Hello there, i bought a awa dual alarm clock radio cd player, but its not playing, i dun know whats wrong, i did not get any manual, can u help me pls...
are settings on correct position? Alarm/alarm sound/radio....am/fm .. CD slide must be on correct setting or you will only get alarm working
Mar 08, 2010 | Audio Players & Recorders
My front loader reads disc error or unplayable no matter what disc I insert. It worked just fine for about 2 years. It doesn ot get heavy cd use, but everyday radio/alarm use.
To resolve this issue, try one or all of the following:
  • The Wave® music system is designed to play commercial CDs, CD-Rs, MP3-encoded CDS and CD-RWs. If your system has trouble playing MP3 CDs, make sure the discs were recorded with compatible formats. See Cannot play MP3 CDs
  • The system may not be able to play certain CD-RW discs. Playability is dependant on how the disc was recorded, including the format it was recorded in and the actual disc used for recording.
    Note: iTunes defaults to AAC as the encoding format. In order to use iTunes to make CDs that will play on the Wave® music system, you’ll need to change the format to MP3 How to Choose Import Options
  • Different brands of CD-Rs and CD-RWs use different materials which may affect the ability of a player to read them. If you are burning your own CD-Rs or CD-RWs, experiment with different brands of discs
  • If a commercial disc won’t play, check for scratches, fingerprints or other physical damage. Try the CD in another player. If it still won’t play, there may be a problem with the disc
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug the system back in
Dec 05, 2009 | Bose Wave Radio
It don't play audio through cd or dvd
are you running audio through an amp? if you are, you are probably using the power antenna remote wire instead of the amp remote wire.
Nov 16, 2009 | Audiovox VM9512 Car DVD Player
Cd player doesn't play.
If you are using a pirated cd or self compiled cd, chances they don't play. try the original cds
Jun 26, 2009 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
May 05, 2017 | Bose Wave Radio
Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 15, 2007 | Emerson Smartset Clock Radio
197 people viewed this question
 Grubhead
Grubhead
