Question about GE GSS20IEP Side by Side Refrigerator
The feeder tube for the ice maker freezes and water leaks inside
And out the bottom of the unit. I have thwaed it out twice but the frozen line and leaks returned both times. It is a side by side GE unit. Thanks.
  • 58 Answers
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Posted on Jun 25, 2009
How can i turn off the water function on the door but not the ice, the water line keeps leaking on the back of the frig
When I had this problem the water was coming from the top right rear where the water tube feeds the ice maker. The water line INSIDE the frig that feeds the ice maker occasionally freezes up causing an obstruction which causes the water to leak out the rear. This can only happen when the icemaker activates the water feed. You can remove the tube fitting without fear because the valve that feeds water through the line is at the bottom rear of the unit. If the line is frozen inside I remove the ice bin and tray and use a hair dryer to melt the ice.
I have a similar problem with the condenser fan making a tapping/clacking noise which is also a result of ice building up on that. Wish I had a different frig but for now the hair dryer will have to do.
Feb 06, 2012 | LG LSC26905TT Side by Side Refrigerator
The water line that connects to the back top of the fridge busted loose. It looks like there is an adhesive pad that keeps it in place. How do I fix it? Scott
Hi Scott and welcome to FixYa, I am Kelly
The plastic line that connects to the ice maker rubber FILL tube is what came off. Check inside the freezer and squeeze the end of the rubber tube at the back of the ice maker. I would bet it is frozen with ice. (Hand held hiar dryer for quite a while to defrost the tube FYI and do NOT melt the plactic of the ice maker water funnel.) What causes the tube to freeze is the inlet water valve starts bypassing water when it is supposed to shut off. The result of this bypassed water is a frozen rubber tube and the plactic tube on the back of the refirgerator blows off or leaks. This inlet water valve is NOT repairable.
The Fix... Replace the inlet water valve and make sure the rubber ice maker fill tube is defrosted BEFORE re-inserting the plastic tube back into the rubber fill tube. It just pushes in and the adhesive pads for holding the plastic line in place are not critical even if they are lost. The rubber fill tube fitting will retain the plastic hose just fine as long as the ice maker end of the tube is not frozen from a leaking inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | Refrigerators
Ice maker not making ice water dispenser works well
There are 2 solenoids, one controls the water dispenser the other controls the ice maker water supply. Follow the tubing down the back of the refrigerator to find the ice maker solenoid. If the line is frozen between the back of the refrigerator and the ice maker it won't make ice either. If the line is frozen you need to check to see if the solenoid is leaking, this allows a trickle of water to continously flow through the lina and freeze.
Jan 08, 2011 | Refrigerators
Ice maker stopped working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Mar 02, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Ice maker quit, water still dispenses
even though you still have water dispensing you may have a frozen line to the ice-maker, take out your ice-maker and check to see if the feeder tube has ice in it, take a drinking straw and insert it into the feeder tube for the ice-maker and see if you can push it all the way to the valve, it's lite enough not to damage the feeder and strong enough to break up whatever Ice might be blocking the tube
Feb 16, 2010 | Kenmore 53642 / 53644 Side by Side...
Ice maker does not produce ice, it was clogged with ice. so i fixed that . the tube coming down from the top was what was clogged frozen . red light is flashing twice repeatadly. need info to fix. thank...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 27, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leaking from top rear left of refrigerator and dripping on coil line in the back of unit. Inside is dry and no water on floor yet. Is it the ice maker connection? If so how do I access it?
You will have to remove the ice maker , to have access to the fill tube . Only 3 screws , hold the ice maker on . After removing , make sure the tube is not frozen inside , and that it is securely , pushed inside the fill tube holder . If frozen inside , then the water valve behind the refrig , where the wall water line connects to , on the refrig , will need replaced also , due to " seeping " , not closing completely , after filling .
Dec 20, 2009 | KitchenAid Refrigerators
Kenmore - ice maker won't produce but water in door fine
Most of the times the solenoid ( electric valve that lets water from the line when the ice maker calls for it) leaks and this little water freezes up inside the filling tube for the ice maker , in tnis case the solenoid has to be replaced.
Oct 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
GE GSS20IEP Side by Side Refrigerator Logo
273 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
