TV green light goes on, no picture, no sound, nothing. connected to Direct TV dish. Power surge?? Help What can I do
  • 1 more comment
  • mrosner2 Jun 17, 2009
    I thought I should tell you the model;;
    The TV is a Sharp L26DV12V; It is a HDTV DVD COMBO.
    The TV green light goes on, no picture, no sound, nothing. It is connected to Direct TV dish. I have disconnected the input. I have herd about a Power surge?? Any think else that I can do except wait?
    This happened a week ago and I pushed the up buttons on the channel and volume, then plugged in the TV and turned it on, It then searched for a signal, found it, and I had picture for 5 days. Now nothing.
    I hear the clicking sound, so I thought I should tell you the model;;
  • 5,807 Answers
Still the same, you will have to do what you did last time, first turn on your TV without connecting the direct TV dish , then connect the direct TV dish after turning it on, or try connecting a disc player or a video player select video input from which you have connected the player and see if your TV can power up, if still wont, there might be a setup problem on your TV
Posted on Jun 18, 2009
    Scholar:
  • 174 Answers
This seems to be TV internal circuit problem. It is quite possible to have loose connection on the TV circuit board, which co-ordinates between the display unit with the sound devices.
Consult a local guy who can fix this.
good luck.
saumya.
Posted on Jun 17, 2009
    Genius:
  • 1,341 Answers
It seems that your dish is not picking any signal or there might be obstacle in the path of the dish.This usually happen when there is lots of trees around.Try to plug a dvd to the tv and if it works then it's most probably your dish or digital box.Hope this helps..
    President:
  • 987 Answers
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
What to test with voltage meter for non working Sony TV.
There may be an internal fuse that has burned out, but opening the cabinet on a TV of any sort is a dangerous thing to do if you're not sure what you're doing!! This needs to go to a repair shop -- or the dump. (It's probably cheaper to buy a new one than to have it repaired.)
Aug 27, 2016 | Sony Televison & Video
No Picture/No Sound
This is very possibly a power surge, can you tell me how many times the light blinks, you probably have a bad power board now if you had a power surge.
Aug 11, 2007 | RCA HD52W59 HDTV Projection Television
Toshiba 55 55S41U Black screen no back light no picture green power light
have you checked for dry joints or blown capacitors , with a power surge depending what kind voltage or amperage the circuit received it might have even blown screen connect it will certainly fry a lot of components ,have you looked for holes in capacitors ,resistors or burnt tracks between components . that's about all I can think of to check also some power panels have built in fuses to stop surges if you could obtain a circuit diagram that should help you also you could google your query and see if you get any assistance it costs nothing and you could get your TV up and running again . All the best .
Dec 19, 2015 | Toshiba Televison & Video
Receiver goes off and screen turns green
Hi there! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to assist you. Please reset the receiver by unplugging it from the wall for 10 seconds. After 10 seconds please plug the receiver back in, allow it to power back on by itself, it will acquire signal and download the guide. If issue persists and you currently have the receiver's power cord connected to a surge protector, please by pass the surge protector and connect the cord directly to a wall outlet. If issue persists after performing this steps please email me at: kimberly.escobar@dish.com for further assistance. You can also contact us directly at: 1800-333-3474.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Mar 14, 2014 | DISH Network ViP 211 DTV Receiver
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light
Try plugging it into the wall direct. Sometimes if you have it plugged into a power strip with all kinds of other electronics like your DVD, XBOX, SOUND SYSTEM, Etc. it may not have enough surge power to start up.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Tv will not power up.
Silly question but, did you try to reset the TV by unplugging it for 2 minutes then plugging back in? Its worth a shot if nothing else.
Feb 01, 2007 | JVC AV32F476 32" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
