Question about Nokia 1100
Power startup i cant start my celfon, the battery is ok coz i change it with another celfon, when charging it will jz blink once i push the power button, but it wont open. pls help... tnx sony ericsson k608i
Re: power startup
...gudday 2 u,,,it is not d battery and it is not d power switch,,it is on d software,,,you can overcome dis problem when u reprogram ur cp,.its been twice dat my cp have d same problem...remember reprogram is d best solution 2 d problem of ur cp,,,jawbreaker!!!!
Posted on Mar 05, 2008
0 characters
3 Points
How can I tell when my cell phone battery is beginning to run low?
The battery icon up at the top of your celfone screen turns red. Green means its full charged or half charged, yellow means it's 25% charged and red means you have to charge it already.
May 18, 2011 | Motorola Cell Phone
My celfone unit is Nokia 6730 classic. how will i
Hello i hope u 'll be fine.... thanks for using fixya
  • just remove the back cover of your mobile by just pushing it towards you with soft hand. There will be a battery inside it. Put 1 finger in down side of battery and push it on upper side. Battery 'll be removed.9594bdb.gif
  • u can see the way from the image
You can also get easily get the manual for Nokia 6730 classic Download it and Enjoy
You can also see lots of effective information of your product from this.
  • Manual is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u. Best of luck
Please do rate if u like the solution
Mar 02, 2010 | Nokia 6730 classic Cell Phone
Cant turn on model 6610. Battery charged ok. on button on top depresses, touch pad lights up then blinks off
cant turn on model 6610. Battery charged ok. on button on top depresses, touch pad lights up then blinks off
Feb 13, 2010 | Nokia 6610
Cant get it to turn on, it wont charge right. I put it on the charger, red light blinks and then stops. It will turn on, then right back off
Plug your phone in the charger and then take out the battery and put it back in. Or you can push the button to turn your phone on and then plug it in while it is starting up and it should catch on and start charging. It is definitely an annoying glitch, but a simple solution
Oct 12, 2009 | LG Incite Cell Phone
Red blinking light and celfone wont power up
Try charging it over night if that doesn't work take it back and they will fix it (it might be a power fault)
Oct 03, 2009 | Sony Ericsson K700i Cellular Phone
I hace a cect i9 phone still in box, but will not turn ON. It worked the first day I bougth it cause I tested it.I have charged the battery but still will not turn on. Is there a service location in...
you should have 2 batteries with it ...take battery out put other one in making sure in correctly seated...plug into pc via usb see if charging icon comes on ...once enough charge in to startup phone try other battery ...when charging you can press and hold top button on phone to startup if enough power...
Sep 11, 2009 | Dual Electronics CECT P168 Cellular Phone
Nokia 6300 Wont Start
Feb 01, 2009 | Nokia 6300 Cellular Phone
My nokia 3310 has no power.
remove inner case n check the on off switch is working or not if it works , then u hve to change power IC.
Oct 19, 2008 | Nokia 3310 Cellular Phone
PLease help me with my Nokia 6288... Thanks!
hi there i have had that problem once, and i'v solved it.
for the heating of the battery and no lights, no display, no signal its all for the flex(ribbon) problem all i did was remove again the flex and clean the contacts sometimes it shorts i just re-solder the contacts of the flex. because some of parts that we bought is not 100% ok. just try it again maybe you'll make it.
Mar 28, 2008 | Nokia 6280 Cellular Phone
Overcharging celfone
I would suggest replacing the battery and try not to overcharge the new one
Nov 29, 2007 | Motorola Mobility RAZR V3
Nokia 1100 Logo
76 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
