Question about E-Machines M5310 Notebook
My backlight keeps going out...and then back on...then out... what to do?
  • 61 Answers
Sounds like a bad LCD to me.
First check warranty status by calling manufacturer as if you work on some of this stuff yourself you voice the warranty!!
If this is in the laptop, you might want to reseat the lcd cables to make sure they are screwed down snug. If this does not fix it, replace the LCD panel.
If this is a desktop LCD i would try another one. If the other lcd works, replace the LCD.
Posted on Jun 17, 2009
Samsung LED backlighting turns off
The only cure for this is to get it repaired and stop smacking on it before you do some real damage.
Jan 24, 2013 | Samsung NP300E4C-A02US Laptop
Does my dp46840 need the shroud over power supply?
Not likely. The shroud is used for keeping out interferences. Not your case tho...
Jun 11, 2012 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
Picture keeps going out on Philips TV 47PFL3704D/F7, 2009 model. The sound stays on. It happens very randomly-may be fine for several hours, may happen every few minutes. Also happens when playing video...
I think that the connectors from the backlight inverter board that go to the LCD panel's backlight are a bit loose which explains why it comes back on when tapped. I am positive that unplugging and replugging the inverter cables should do the trick. WOuld like to do it yourself? It requires you to open up the tv ofcourse.
Jul 10, 2011 | Philips 47PFL3704D 47 in. LCD TV
I have a 37in, the screen keep going blank for a bout 5 seconds and when it comes back on the constrast goes up to 100
This is a combination of the backlight inverter and the mainboard. It is going into fail safe mode when the backlight is failing and resetting to default settings. I believe once you change out the backlight inverter that your problem will be solved. Also, check for popped capacitors on the powersupply to make sure that the backlight inverter is getting the 24v it needs to operate properly.
Please rate if this helped :)
Mar 11, 2011 | Samsung Televison & Video
Gateway M-1631u screen keeps going to full backlight power
Connect an external monitor to your laptop. If it the image is ok on the external monitor and bad on the laptoop screen it means one of more of backlight/inverter/screen is defective. Have it repaired by a professional.
Oct 09, 2009 | Gateway M-1628 Notebook
Display light keeps blinking (dimming).
most likely inverter is on its way out
if it does it a lot when you move the lid back and forth it could be a cracked display cable
Apr 30, 2009 | Computers & Internet
Back light and sound
have you checked your settings and made sure have the backlight and dimmer setting high enough there in your settings under personalize then choose backlight and check your tme
Feb 28, 2008 | Sony Ericsson K800i Cellular Phone
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
E-Machines M5310 Notebook Logo
319 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
