Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice Dispenser motor/Dispenser light
I have replaced the front panel switches, i.e. the control on the front of door, which are only snap switches.  When I meter the neutral wire on the light I get 120v on both the hot and neutral side and the light does not work.  Also I get 120v on the neutral side of the dispenser motor.  If I disconnect the dispenser housing heater the 120v disappears but the light still does not work.  This heater is ohmed out at 6.5k ohms.  The water dispenser works.  It is not the micro switches.
If I test the motor buy taking it out and hooking a 120v across the blue wire and white the motor still does not work, I believe the other wires are for the DC conversion for crushed/cubed ice according the wiring schematic.
  • 146 Answers
I assume that the problem is that the ice dispenser is not working. If you have put 120v onto the auger motor and it won't go, then obviously the motor is faulty. Reconnect the motor to the wiring harness and put your tester on the white & blue wires. Push the door switch so the fridge thinks that the door is closed and push the ice dispensing lever. If you get 120V to the motor and it won't go, replace the auger motor.
Posted on Nov 03, 2007
Dispenser door opens, but auger motor doesn't operate for cubes or crushed ice.
I believe that voltage to the auger motor should be DC voltage. Yes it could be a relay on the board causing this and it could also be the Auger Motor 2252130
Dec 06, 2015 | Refrigerators
Maytag mfi2568aes control panel
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
May 16, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Ice dispenser doesnt work
Have you tried taking your ice bin out and checking for melted ice that can freeze locking the auger and preventing its movement? Another item to check is wiring going to and from the dispenser. Many times corrosion sets in the pin plug just behind kick plate. If the auger motor is not turning at all then I would believe that you may have a defective door light switch that also controls a lockout when door is opened. That light switch tells when door is opened while the opposite happens when door is closed. If that fails then we need to see how much voltage is present at the auger motor leads just behind the rear panel of your freezers auger motor assembly. To test the auger motor leads you need to have someone hold door light switch in and press dispense ice while someone checks motor leads with a voltage tester. If you have questions I will be glad to answer them for you, Thanks, Sea Breeze
Apr 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
GE Profile 2006 Icemaker (icemaker model: wr30x....) doesn't make ice but cycles perfectly when jumped. Making 8 ice cubes at a time by jumping is cumbersome however. Can you explain how to get the...
The flexible arm is the on off switch to the timer. And the timer is in the ice maker itself. Make sure that arm is in the correct position.
Sep 13, 2010 | Refrigerators
GE Profile refrigerator panel on front has stopped responding to requests for ice. It give water, but no ice. Any ideas on what is needed?
Yes, we will need to check the wiring from the motherboard to the dispenser controls. Also we need to test the door switch. The door light switch works two ways by turning on light when open and turning on dispenser controls when closed. Sometimes the door switch is bad. I have a link and will work with you to solve this, Let me know, Thanks, Sea Breeze
Apr 18, 2010 | GE Profile PSS26NGS Side by Side...
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
Ice dispenser will not dispense ice when selecting either crushed ice or whole ice. I replaced the motor but it still will not work.
Your door switch may be the problem, it is a double pole single throw switch. When the door is closed the switch directs power to the dispenser. It also could be the control module in the dispenser panel. Not knowing your model number I must assume you also have a mother control board on the back of refrigerator. Send the model number found on the bottom of the fresh food section door frame and behind the door seal. Hope this helps, feel free to ask me more questions and please rate me! Thanks, Sea Breeze
Jul 29, 2009 | GE Refrigerators
Door light, on/off switch, water and ice dispenser not working
First of all if your water dispenser is working then we know that the control panel is getting power. If not open the door and manually press the door switch to see of the switch is working properly. The switch will cut power to the dispenser to prevent operation while the door is open. Second you need to check the wiring at the hinge to see if there is a break in it.
if you are still having trouble please respond with a model number
Apr 15, 2009 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
202 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
