Question about Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine
Out of range
Reads out of range for hours now. is fully charged and only inches from base problem persists.
    Problem Solver:
  • 3 Answers
Change the sim card. the problem lies in the sim
Posted on Jun 17, 2009
After charging battery,the phone dial reads, out of range,or no pwr at base
Double check that the power cable is _fully_ plugged into the phone base, then check to see that power cable is fully plugged into wall outlet; and/or fully plugged into phone wall outlet. (Some base units have no power adapter and get their power from the phone outlet on the wall). In short, double check _all_ wired connections. Do not assume they are fully plugged in.
Aug 15, 2015 | Vtech VT-CS6114 Cordless phone w/ CID/...
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
I have a uniden phone wdss 5335 +1 and have had it on charge for more than 15 hours , little bar indicates fully charged. But phone set says out of range so phone doesn't work, can you help?
Either the base unit is turned off or it is located too far from the phone that says it is out of range.
The base unit is the one that has the phone cord connected to it. If the phone situated on the base unit is working, then the problem is just one of location for the phone in question. If you have several of the Uniden phones, you might try relocating the base unit to other locations with a phone wall jack. For example, a frequent problem is that the base unit is on a kitchen table behind a refrigerator which is acting as a shield to the phones' electromagnetic signals. Moving it out from the refrigerators "shadow" might solve your problem.
Mar 17, 2011 | Computers & Internet
I was reading my 600 Sony Reader when all of a sudden there was nothing on the screen. I attached it to my computer but the light has never come on and there is absolutely nothing on the screen.
It seems that the Reader is frozen.
Slide the Power Switch to the OFF position and press the reset button, located at the base of the Reader, using a sharp pointed object. This may resolve the issue.
However, if the issue persists, connect the Reader directly to the USB port of the Computer using the supplied USB cable and charge it for 3-4 hours.
After charging the Reader, try resetting it again.
If the issue still persists, the Reader may require service.
Mar 02, 2010 | Sony Reader Touch PRS-600
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
Hello, yesterday, I purchased an AT&T 3 Handset phone set with the model no. of EL52309 and I came home and read the directions that said the phones needed to be charged for at least 16 hours and so...
is the base in range of the other two bases, have you set each phone in the main base so they get aquainted., are you shure all plugins are snug? try a different telephone wire to hook up to the base from the wall (might be a bad wire) if that persists, try relocating the base, and test it their, if you are still without dialtone use a cell phone and call your tsp say it randomly stopped working and that you changed nothing... they will send someone out :P
Jul 08, 2009 | AT&T 1717 Digital Answering Machine
Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
joequevedo@charter.net
May 07, 2009 | GE 27992GE5 Cordless Phone
Battery holds a charge for a short time only
These phones are known for the contacts not transferring adequate voltage to fully charge the phone.
Oct 23, 2008 | GE 26928GE1 Cordless Phone
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Nov 25, 2007 | Uniden Lands Phones
Uniden 2.4 GHz Expandable Phone System with Digital Answering Machine Logo
75 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
