Question about HP Officejet 4315 All-in-One Printer
I send a document to the printer to print and it will not print
    Scholar:
  • 94 Answers
Try cancelling that document job by right clicking on your printer status icon then canceling it. Then, restart your printer, and check any paper jams/paper. hope this helps :)
Posted on Jun 17, 2009
How to print pdf document in lipi 6306 printer
It depends on what you mean by printing a PDF.
You can not "Direct Print" PDF documents on the 6306, you will need to pass the document through an appropriate printer driver / filter depending on the operating system used.
Simply sending a PDF document to the printer will not work
If you are using Windows simply print the PDF from Adobe Acrobat using the appropriate Windows Printer driver. If you can print a Windows Test Page, you should be able to print a PDF document- The quality of the print may not be of laser printer standard- Remember this is a Line Dot Matrix printer
Apr 03, 2013 | Tally 6312 Matrix Printer
How do I get my HP Deskjet D1455 to print in color?
Select the document which you want to print.
give the print command.
Open the printer properties.Look for the option features and printing
Select color printing .
Your printer will print the document successfully.
May 21, 2012 | HP Deskjet D1455 InkJet Printer
I can send a document to the printer and print,
check the settings on the driver software, next check the configuration on the printer
Mar 19, 2010 | HP Photosmart C5280 Printer
Yellow light flashes but won't print. Paper tray is full.
If you had sent the document for print, try cancelling it and switch off the printer, unplug the USB cable to the printer and plug it again. Put on the printer and send the document for printing again. Make sure that no other document is pending for printing and send for print again.
Regards
Sep 26, 2009 | HP LaserJet P2015dn Printer
EPSON POS PRINTER does not print receipt
Try to clear your printer's queues up messages of all print commands that failed to print. See, what happens it when you send a document to printer, if it fails to print, and you send another, it queues up behind the first that failed to print. So instead of printing the second document it prints what you are seing, special characters etc.
Solution:
Go to start/priners and faxes and right click on your printer and select open. You will all the documents for print so far queued up. select and delete them. Restart your system and the printing should be Ok.
Sep 17, 2009 | POS X POS-X XR210 Thermal Printer
Printer sends out extra page everytime I print
either your paper size settings need to be adjusted in the software, or your setup has included a seperator page.
Jan 27, 2009 | Office Equipment & Supplies
Can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Jan 16, 2009 | Office Equipment & Supplies
Ben Johnson
