Question about Nikon F60 35mm SLR Camera
Will not turn on and doesn't show the screen. Battery is hot.
It was in my car when a storm came up with lighting. I have pushed the reset button. will not let me take a picture. It has happened suddenly
I have not had any trouble with it and have been very pleased with it. I have only had the camera since January. Bought it off e-bay. It is a nikon 60. It shows in the view finder an E. don't know how to fix it myself.
    Brigadier General:
  • 8,619 Answers
Hi
E blinking is very popular symptom. Make sure your lens is set at F22. Your lens is not set to the smallest aperture (highest number). Turn the camera off, rotate the aperture ring so the largest number is lined up with the mark on the top, push the aperture lock tab, and turn the camera back on. The aperture ring is the one closest to the camrea body with numbers like 4, 5.6, 8, 11 etc on it. The largest number will be 16, 22, or 32 for most lenses. If it still doesn't work, turn off, remove & replace the lens, and recheck the aperture ring setting.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 17, 2009
I press on startyer button and it just click all lights and turn signals are working
Make sure your battery is fully charged & the terminals are clean & tight. If they are ok check your solenoid. If thats ok check starter. Hope this helps.
Jul 02, 2011 | 1984 Honda VF 750 S
I had the oil changed but the change oil light is still on, how do i reset the computer? 2000 oldsmobile alero
How to Reset the Change Oil Light
After changing the engine oil, the system must be reset.
With the ignition key to ON, push the RESET button
located in the driver's side instrument panel fuse block. The
CHANGE OIL light will start to flash, press and hold the
RESET button again. The reset is complete when you hear
the chimes sound and the CHANGE OIL light goes out.
Oct 25, 2010 | 2000 Oldsmobile Alero
Omnibook xe4500 long beep and now will not post bios. This happend when I was trying to boot to the DVD to reload the OS recovery disk. All the lights above the left side of the keyboard are lit up with...
screen never shows words, ever, does external screen work
at VGA port?
no bios does not just bug out , like ELVIS.
its ROM , ROW will not forget, (99.999999%) of the time.
good for 25+ years, by DESIGN.
unless humpty is pushed by geeks playing bios flash games.
this notbook is old , Pentium 4 , square screen , omg, old
512kb mem. ouch
HDD 30GB. (tiny)
first is what, try this
1: battery out. (big battery, ) take it out.
2: coin cell 3v not 2v, or its bad. replace coin, as all this old are bad.
3: power pack good. must put out full 19vdc voltage , does it? now.
4: BIOS hot keys work, (mine is ESC , key) is yours?
5 still no bios. does a flash light pointed at screen show data there?
yes/ no/. yes, back lamp burned out (or the DC/DC inverter card)
no screens, black screens still...
6: still dead, remove HDD, and DVD. drive. still dead.?BIOS> get BIOS working first. use the hot key.
remove all; easy things, even USB things.
7: remove all extra memory, RAM, if 2 sticks try 1. then run other by self. if runs now, ram removed is bad.
there is more, there are over 3million transistors there.
see black screen #1 here. goes into all steps, all paths for dead.
http://pcdied.com/
Apr 17, 2017 | HP OmniBook XE4500 Notebook
NOTHING SHOWS ON THE SCREEN OF BLACKBERRY STORM, HE CANNOT SEE THE KEYS TO FIND THE MASTER RESET, IF THERE IS ONE.
If you are able to see any light lit on you are blackberry.First charge your mobile for atleast 1 hour,and switch it ON you have to remove the battery when mobile is turned ON and wait for few seconds re insert the battery then check
If problem still exsists connect your blackberry to computer check wheather its recognising the device If "yes" you need to take a back up of your hands set and re-install the operating system of your Blackberry. Or else please visit the nearest service centre.
Nov 22, 2009 | RIM BlackBerry Storm 9530 Smartphone
I got a can not play media while phone is active message. Than I turned off and on the phone after that didnt solve my problem, I pulled out the battery. When I put in back in and tried to turn on the...
Remove the memory card and the battery from the phone.
Press and hold down the power button for 15sec.
Now put the battery back in and check.
If it works, you can out the memory card back in.
Jul 14, 2017 | RIM BlackBerry Storm 9530 Smartphone
Can not turn on! my garmin nuvi 200w I think it is locked,
if ther battery went totally flat place it on charge for an hour or so to revive it. Max battery life in storage is 4 days with a good battery.
Charging it even tho the charge light may not show should build up enough charge to eventually show the light and allow you to turn it on. It should remain on charge for 5hrs.
Other possibility is a collapsed cell in battery, replace the battery
Jul 24, 2009 | Garmin nuvi 250 GPS Receiver
When click bb button my options buttom doesn work
If you are at the home screen and the phone is unlocked, press the "blackberry" key, next to the green answer button. The on screen menu should show "options". If you click on this, nothing happens? If it does pop up with the next window, the row adjustments are in the middle of this screen under "Set Homescreen Layout". Once you have selected this, be sure to press the blackberry button again and save your selection.
Hope this helps!
May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Display will not show when tv flips out!
MOST SCREENS R NOT ON IN THERE RESTING STATE, THERE USUALLY A MECHANISM THAT TURNS THE SCREEN OPEN WHEN IT OPENS, TRY SLIGHTLY PUSHING THE SCREEN BACK LIGHTLY TO SEE IF IT COMES ON HOWEVER IF U CAN RESET IT , TRY THAT IF THAT DOESN,T IT WOULD HAVE TO BE REPAIRED FROM THE MANUFACTURE
Sep 02, 2008 | Panasonic DV-169 Valor DVD/VCD/CD/MP3...
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Nikon F60 35mm SLR Camera Logo
63 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
