Question about Whirlpool ET1FTKXK Top Freezer Refrigerator
Have done these tips, but...
I have done the thawing/cleaning thing several times. It's not a permanent fix. I'm weary of doing this process every month! Why does the condensate drain hole keep freezing up and what's a permanent fix?
    Guru:
  • 462 Answers
A defrost termination thermostat could be the trouble. It could cut off the defrost heater before the temp is up high and long enough to clear out the water from defrost. the stat is either the size of a quarter or a dime depending on which you have and it is located usually on the evaporator coil. If you inspect it after running for a week after your lastm clean up it will also tell you if the coil is completing defrost. look for signs of the frost starting to build up on the evap inside coil. If it is starting this also and is most of the coil covered with frost the defrost stat and timer bothe should be replaced if you dont want to have a repeat problem. If the frost is really thick you need to check the heater as well. A bad heater usually wont last a month though. 2 weeks in 30 to 60% humidity is about all it can handle. If your humidity is lower or you dont open the doors every day 4 to 8 times or more it may last a month also. All this is assuming you ahve a self defrosting model though.
Posted on Jun 17, 2009
The unit stopped cooling the first hot day this year. it used to get warm and freezer items would thaw if the room hit 85 degrees. can this be reasonably fixed
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 07, 2011 | Microwave Ovens
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to...
heatman101
Mar 18, 2011 | Refrigerators
Sometime freezer thaws then refreezes model59675232400
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 26, 2011 | Kenmore Refrigerators
Does not cool; frozen foods are thawing out.
Refrigerator
heatman101
Jan 13, 2011 | Whirlpool Refrigerators
Icemaker does not work and things are thawing in the freezer
heatman101
Dec 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore model #65802 - freezor sometimes is completely thawed, other times seems to be freezing OK - fan is running. What could cause this?
Refrigerator
heatman101
Dec 14, 2010 | Refrigerators
Compressor clicking every 3 minutes food thawing out water on floor
heatman101
Nov 20, 2010 | Refrigerators
Refrigerator fan is running but there is no refrigeration happening. First noticed it a few hrs ago when preparing to fix dinner. All foods in freezer are thawed. email me at dijagro@gmail.com
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 16, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Items on top shelf and top shelf of door are thawing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 13, 2010 | GE Refrigerators
Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
Jul 10, 2008 | Sega Genesis Console
Whirlpool ET1FTKXK Top Freezer Refrigerator Logo
132 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
