Question about JVC TH-M303 System
My dvd player is locked
I own a JVC TH-M303J. I tried to remove a disk and it comes up locked what do i do to unlock it so i can change out dvds
  • 341 Answers
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Posted on Jun 17, 2009
To fix locked disc tray on a TH-M606, TH-M603, TH-M505, TH-M501, TH-M303, TH-M301:
While the system is turned off. Press and hold the STOP button and Disc 1 EJECT button at the same time (only 2 seconds). If done correctly, it should turn on and read "UNLOCKED" on the display. Doing these steps again will re-lock the system. A great way to prevent someone from using the dvd player.
Source: Pg.36 in the manual "Tray Lock" feature
Posted on Dec 29, 2011
  • Nick Gascon
    Nick Gascon Dec 29, 2011
    If still stuck here's a link to the same manual in PDF form:http://www.google.ca/url?sa=t&rct=j&...
Dvd player unlock codes
This can indicate a bad disk or a disk not recorded in DVD format, you can check the disk status and format in your computer with DVD drive and a player software as VLC.
Aug 16, 2014 | JVC Televison & Video
Unlock region code for JVC dvd player
if your dvd player is not region free it will not play us dvds it will only play burnt dvds and dvds from your region unless u buy a region free dvd player
there is no region free code for your dvd player
Apr 04, 2009 | JVC XV-E100SL DVD Player
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
How do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Oct 15, 2008 | JVC TH-C60 System
Region code
To my knowledge, due to firmware design, most JVC region locked DVD players can not be unlocked with entry codes through the remote. While some JVC models could be unlock with a firmware update or a PC interface neither of which is available for a TH-P3.
Im sorry but thats just it for this model.
Alternately, a long method is to convert/copy the DVD disc itself from any region to whatever region your JVC is locked into. There are freewares just for this purpose. An example is DVD SHRINK 3.2.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 29, 2008 | JVC (01266)
I try to open my JVC TH-M508 DVD player & it comes up on the screen "locked". I assume the children have pushed something. I now would like to be able to unlock the player so we can change...
OK , use the remote and go for menu of DVD PLAYER , LOOK for SETTINGS , PARENTAL CONTROL , or PASSWORD , THEN WHERE it say locked , just click unlock , depending of model system , hope this helps & good luck AJ
May 14, 2008 | Televison & Video
Unlock code for jvc dvd
hi if you can help me i have a dvd jvc th-a35 and it wont play all the dvds what is the number or how i can unlock to play all dvds
Nov 25, 2007 | JVC TH-A35 System
Jvc player wont open door its saying locked
I cannot unlock my JVC DVD player the work lock appears in the window
Nov 11, 2007 | JVC TH-M505 System
How do i unlock my jvc th-m505 dvd digital theater system?
Hold the STOP button and push the EJECT button.
May 15, 2007 | JVC TH-M505 System
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
JVC TH-M303 System Logo
621 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
