Question about Freezers
50-plus-year old Kelvinator chest 14 ft3 freezer.
The temp control unit is no longer available.  I bought (nonreturnable) one that controls from 1F to 20F thinking I could keep it at 1F.  But the temp is -18F at the lowest setting.  Any suggestions?  Two repairmen told me I should keep the freezer as long as possible.  I am not sure why they suggested that I keep it.
Harry Carpenter
murphyblack@roadrunner.com
  • 72 Answers
Use a temp controll from another freezer, it is just a temp switch.
DIY repear and diagnosic help:
http://www.acmehowto.com/howto/appliance/freezer/freezer.php
http://www.repairclinic.com/0047_3.asp
http://www.fridgedoctor.com/
Posted on Nov 12, 2007
What is the size of Kelvinator chest freezer?
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Jun 26, 2014 | Kelvinator Freezers
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    My magic chef freezer will freeze for a day and then the temperature will increase to 70 degrees. The freezer is just two years old. Is it worth having someone to come out and look at it or is it...
    This is a manual defrosting freezer so the most likely cause is the temp control. Sad that is is only 2 years old but the temp control is not working correctly.
    It sure sounds like it is running until it cycles off at the "I reached the cold enough" SET TEMP then never starting up again. That start up is controlled by the temp control. Call and make SURE the temp control is called the thermostat!
    1-888-775-0202
  • Available 7:30 a.m. to 7:00 p.m. central time, Monday - Friday
  • The Part number is WPF24B-L and the only source is Via this link: http://www.mcappliance.com/partorder.aspx
    List Price $22.95
    Thanks for choosing FixYa.
    Kelly
    Sep 05, 2010 | Magic Chef Chest Freezer MCCF5WBX
    Temperature swing specification in a chest freezer.
    It depends on the control that your freezer utilizes.
    If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
    Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
    With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
    So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
    Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
    Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
    Kelvinator fridge freezer is a geiger counter
    something could have fallen into the fan between the two compartments
    Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
    Meat along the outside seems to be thawing out.
    HI, If you want the temp warmer, move the control to the smaller #'s
    If there are no #'s, turn the control clockwise and see if it shuts off. if it shuts off, that is the right direction for warmer temps.
    I hope this helps you. please let me know.
    Vic
    May 31, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
    Kelvinator Chest Freezer will not cool after spray painting rust spot.
    Dear Landport2
    Welcome to the site,
    You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
    How old was your freezer?
    This must be an ancient freezer!
    And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
    You did not cause this!
    Unfortunately it was so old that it probably was already on it's last legs.
    Here is an interesting report I just read!
    Repair or replace your appliances?
    When to pull the plug on your old freezer
    It nearly always makes sense to undertake simple do-it-yourself repairs,
    such as replacing a gasket on a refrigerator or a freezer.
    Typically, you'll also find a troubleshooting section for more-serious problems
    in the owner's manual.
    Should you pay for a repair or buy a new model ?
    The answer depends mostly on the age of your ,freezer
    how much you bought it for,and the cost of the repair.
    Follow these guidelines:
    When a repair makes sense.
    If your refrigerator is under warranty or less than four years old freezers),
    paying for a repair makes sense.
    Note that freezer under warranty might require service from a factory-authorized technician;
    readers have found them on a par with independent repairers.
    When a repair might be a wise choice.
    If your freezer is out of warranty and is four to seven years old,
    it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
    But you might want to buy a new model even at this stage,
    given that today's models are quieter and have added features.
    Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
    are 43 percent more efficient than conventional models built before 2001 and 56 percent
    more efficient than those built before 1993.
    When it pays to replace.
    The repair costs more than half the price of a comparable new freezer.
    Data also shows that it doesn't pay to fix a less-expensive freezer
    six or more years old .
    Thanks to better recycling programs, less than 10 percent
    of a freezer you replace is likely to end up in a landfill.
    Thanks for giving me the opportunity to help!
    Please do not for get to give a rating before you sign off!
    Thank You, HUUUM
    Oct 10, 2008 | Freezers
    Temp
    jtcarlier
    20 Degrees is good
    I am happy to assist you!
    Neil
    PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
    Aug 24, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
    Kelvinator freezer is not freezing!
    you mean it cools but not as afreezer ok, rework again the system properly vaccum and slowly charge it but please watch out the proper amperage of the compressor or might be the compressor motor now is weak, how old this unit,sir.thankyou
    Aug 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
    Freezers Logo
    221 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Are you a Freezer Expert? Answer questions, earn points and help others
