Question about Apple iPod nano
I need to unlock the volume limit code but i don't know the code
When i played the songs,the volume is so low that i can't hear through headphones or earphone also. So is there any solution for that????
  • 22 Answers
Hi Here is a great link with a walk thru to assist you with the volume task :
http://www.megaleecher.net/Unlock_iPod_Volume_Limit_Code
/Shawn
Posted on Jun 17, 2009
  • 26 Answers
This should work, Try what this website says.
Thanks,
Christian O
My apple iPod nano 5th gen wont play music through the headphones right. It only plays through the internal speaker even with the headphones in. I can hear it through the headphones a little but it is...
take the headphones out play the music full volume then put the headphones in and lower the music all the way down then your volume will be normal and it will only play in through the head phones unless you take headphones out then it will play through speakers
Aug 30, 2010 | Apple Logitech Inc MM50 Portable Speakers...
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
My ipod shuffle will play my downloaded songs on my computer but not with earphones?
Make sure the earphone or headphone connector is pushed in all the way.
â Make sure the volume is adjusted properly. A volume limit might be set.
To remove the volume limit:
1 Connect iPod shuffle to your computer.
2 In iTunes, select iPod shuffle in the Source pane.
3 Click the Settings tab.
4 Deselect “Limit maximum volume.”
Enter the password, if required
Mar 07, 2010 | Apple iPod shuffle MP3 Player
Dont know the code to unlock my ipod screen and volume limit
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the device
(or restore from a backup). If you restore on a different computer that was never synced with the
device, you will be able to unlock the device for use and remove the passcode, but your data will not
be present Follow the steps that i have outlined below. If this does not completely help your situation please
let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features
again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note
that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is
to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Jan 04, 2010 | Apple iPod nano
Ipod turns on and works - cant hear song playing
Check the volume using the buttons on it and also in your settings/volume limit. If that doesn't work, resync it with iTunes and see if there is a parental control in place preventing music to be played.
Oct 13, 2009 | Apple iPod MA446LL/A MP3 Player
CANNOT FIND UNLOCKING CODE FOR VOLUME LIMITER ON IPOD CLASSIC BLACK 120GB
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you need further assistance please feel free to follow up with a comment and i will be here to
Jul 15, 2009 | Apple iPod classic MP3 Player
Ipod turns on and plays songs but there is no sound
Hi
Try and use another set of headphones. If you are not getting any sound from the other set aswell then check the volume limit settings in the menu-> settings-> volume limit. And, if limit is set fine then there is a hardware issue which needs to be taken care by Apple service.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 13, 2009 | Apple iPod nano
Volume limit unlock code
Apr 17, 2009 | Apple iPod MA446LL/A MP3 Player
Volume code
As far as I know, there is no unlock for the volume. If you go into settings there is a volume limit. If you go to it just scroll up to the maximum and press the center button. That's maximum volume set. Then play a song and scroll the volume all the way up. If you're still not getting any sound then your headphone cable might be broken. Try the iPod on some sort of docking bay that produces sound. If it works on there then you definitely have a faulty headphone/hold cable. If it doesn't work on the docking bay, then you have a faulty logic board.
Jul 26, 2008 | Apple iPod MA446LL/A MP3 Player
Psp music sound problem
Could you please check the music bitrate you downloaded to your PSP? It should have at least 128 or 192 as its bitrate value to get a decent sound.
Also do not set your PSP volume too high as it may hurt your hearing (when using headphone) or it may hurt your PSP system speaker (when not using headphone).
I recommend you to always enable the AVLS (Automatic Volume Limitation System). You can always choose to activate/deactivate AVLS from the System Settings menu.
May 11, 2008 | Sony PlayStation Portable (PSP) Console
Apple iPod nano Logo
226 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
