Question about Microsoft Flight Simulator X for Windows
I can receive transmission in FSX but not transmit.
When I first installed it, it worked but had to reset computer back to factory settings and reinstall fsx and acceleration.
Now I can't transmit anymore.
Any ideas?
  • Richard Hutchinson
    Richard Hutchinson Jul 15, 2010
    Who are you trying to transmit to?
  • 122 Answers
You need to go into the main FSX screen, choose settings, controllers and set up the button you wish to use to transmit on.
Posted on Jul 16, 2010
Can i delete and re install FSX steam edition using the original install code i got when purchasing FSX
Hello, Neville -
No. You will need to purchase FSX Steam Edition and receive a new install code for it.
I understand many of the add-ons for FSX will work with FSX Steam Edition, though.
Best wishes.
Apr 04, 2018 | The Video Game Consoles & Games
Tip
How to reset wireless keyboards and mice
A wireless system consists of a receiver plugged to the USB port of the computer, a mouse and a keyboard. The function of the receiver is to "listen" to the signals sent by keyboard and mouse. As there might be other wireless equipment operating within range of the receiver, ALL systems, independent of brand, have many different channels in which they can operate, without interfering with other devices. The mouse and the keyboard, separately, have to know which channel the receiver is working on, in order to transmit on that particular channel.
Most system failures (other than depleted batteries) can be attributed to the receiver " listening" to a different channel than the mouse/keyboards are transmitting on.
Resetting the system, to work on the same channel, may vary from manufacturer to manufacturer, but basically all work with a button on the receiver that changes / resets the operating channel, and within a short period of time, similar buttons on the back of mice and keyboards that must be activated in order to "learn" the new channel set by the receiver.
on Jul 18, 2010 | Computers & Internet
Yamaha RX-V359 the remote sensor in in the unit is not working. I have tried the remote control on another machine and that works
If the remote is working, but not with your receiver, there is maybe ID mismatch. Both the remote and receiver can be set to either ID1 or ID2 - this is used when you have 2 receivers nearby, so that both of them don't react on commands from both remotes.
See the "Advanced setup" of your manual. On receiver you can check/change the ID code by powering the receiver on (press STANDBY/ON) while holding down the STRAIGHT button on front panel. Display will show "Advanced setup". Use "program < >" keys to navigate the menu until you got to "REMOTE ID-XYZ". Then press STRAIGHT to select ID1 or ID2. Now press STANDBY/ON to turn the receiver off. After turning it on again, it will use the new settings.
You can also try to reset the remote control codes to factory defaults. On remote, press CODE SET with a tip of a pen or pencil. TRANSMIT light on remote will blink twice. Now press SETUP on the remote and then "9981". TRANSMIT should now blink twice and remote control is set to factory default codes.
Oct 12, 2014 | Yamaha Audio Players & Recorders
I had to reload flight simulator fsx and 5 time it went to the end and I received an error message! and did not complete. Can you help?
Each time you are installing FSX installation is leaving behind files. Get a good quality registry cleaning program. Uninstall FSX, reboot, use the reg cleaner, then reboot, then re-install and you will be okay
Mar 24, 2010 | Microsoft Flight Simulator X for Windows
Two motorola t8550's unable to communicate
1) You did not mention the Qt filter. You might check to see if you have the Qt filter set the same on both radios. This is an additional layer of privacy featured on this radio.
2) Verify you have good working batteries. A bad battery or uncharged battery can cause a no transmit situation.
3) If these do not work, reset your radio back to a basic operation by shutting of the code, Qt filter, call tone, weather alert, Vox/iVox, roger beep, etc. At this point your radio would be operating just on a simple frequency. See if you can communicate with all these special features turned off. If so, slowly add back in the features you desire.
4) If your radios still fails to work and is less than one year old, call the 800 number on the pamphlet, have your serial numbers and radios handy. Your radio if not physically or water damaged is possibly still under warranty.
Most of the time when a set of radios has your problem description, it is the Qt filter, or possible improper use of a special feature such as call tones or iVox. These would be the first things to check.
Best regards.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Mar 09, 2010 | Motorola Talkabout® T8500R Two Way Radio
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
FSX Not responding. Uninstalled every application and add-on. Re-installed FSX, but still will not respond
This is a registry issue. Get yourself a good registry cleaning program, uninstall FSX, reboot the PC. Run teh reg cleaner, then reboot. Now you will be able to install FSX okay. Good luck
Oct 20, 2009 | Microsoft Flight Simulator X for Windows
Don't know how to open chat box on FSX
Hi buddy you can try this. This may help u out
Click the "Chat" button to open the Chat window
(or if you're already in the plane, press the Enter key to open)
I hope this will work. plz vote for me
Sep 05, 2009 | Microsoft Flight Simulator X for Windows
I have fsx deluxe and it hangs on install
Check your DVD discs have no scratches or damage. If this is not the case, get a replacement set from where you purchased it.
Jul 04, 2009 | Microsoft Flight Simulator X for Windows
Garmin Rino 530 HCX Will not receive
check the volume settings for the radio
factory reset is: with unit OFF press and hold PAGE button and ENTER button while holding buttons turn ON unit reset is complete.
May 11, 2008 | Garmin Rino 530 GPS Receiver
Microsoft Flight Simulator X for Windows Logo
140 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
