Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
TV TURNS ITSELF OFF
AFTER TURNING TV ON THERE IS A DOUBLE CLICK EXTRACTOR FAN STARTS UP FOR ONE SECOND SCREEN LIGHTS UP THEN INSTANTLY TURNS OF TO STANDBY MODE
  • info94466 Jun 17, 2009
    thanks will try . reply with resolts
  • info94466 Jul 13, 2009
    Pulling hair out now. Have replaced lamp and casing, thermal switch, lamp cooling fan and extractor fan. TV is still doing exactly the same thing - clicks on, fans starts then stops, lamp lights up momentarily and then tv turns off to standby. Please help.
    President:
  • 1,197 Answers
I belive its ur lamp
One problem involves the lamp cage being loose. The fix is easy. All you do is remove the lamp and put it back in, making sure everything is tight. I guess they had a problem at the factory, for a while, not tightening the lamp cage. They're making these things as fast as the can, you know, in Mexico. After a certain number of heating cycles, the lamp quits making connection.
before we cud go in for a replacement lamp.... there are a few things u need to check
Have you reseated the lamp? Try this...Some times the connector is not being connected well and don't make the full connection.
Also try reopening the cover and putting it back, maybe the sensor for the lamp cover is not fully pressed in.......the door where the bulb is must not have been closed tight enough. open it, reseat the door, and screw it down tight.
it's the mechanical location of the switch behind the lamp door. By design, if the lamp door is not completely secured, the switch will not be depressed and therefore the TV will not start up for safety reasons. What's happening in some of the random shut-down events is the switch is bent a little bit, but just enough to prevent consistent contact even with the lamp door adequately secured. The fix is to turn off the TV, bend the switch out a little so it will make good contact when the door is closed, replace the door, then turn on the set.
The above fix has resulted in complete resolution for many people with this problem.
now i ll have to advice u to have all the safety precautions in place.... make sure the power is off before even ur opwning the unit.... and all necesssary precautions..... if ur not comfortable doing it urself... dont do it as tvs have very high voltage.... in that case i urge u to have a repairman or atleast someone who knows abt tv circuits to do the job....
shud u have to replace the lamp.......
here are the websites from where u can buy the lamp......
http://shopping.msn.com/specs/rptv-lamp-for-sony-grand-wega-kdf-60xs955-part-xl-2100u/itemid1014228225/?itemtext=itemname:rptv-lamp-for-sony-grand-wega-kdf-60xs955-part-xl-2100u
http://www.apexinktoner.com/sony-grand-wega-kdf-60xs955-rptv-lamp.html
u can choose the convenient option of the above two......
the instructions for changing the lamp are given in the below link..... please download that pdf file and proceed as per the instructions shud u wish to change it urself.....
http://akamaipix.crutchfield.com/Manuals%5C158%5C158XL2100U.PDF
please be careful and safe.....
if u feel my service was of any help... kindly rate my service....
good luck
Posted on Jun 17, 2009
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
I have moved into a property with a Sector extractor fan in the bathroom - when you turn the light on the extractor starts up -when you turn the light off the extractor continues to run for a long time -...
On some Bathroom extractor fans there is a setting for the amount of time you want the fan to stay on after you turn off the switch, the setting dial is normally at the back of the fan so you need to take the fan down from the ceiling making sure the fan is electrically isolated.
Mar 31, 2011 | Home
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Panasonic pt56wxf95a turns itself off
Did you replace the bulb? clean dust out of fans?
Apr 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
My bathroom fan will not turn itself off, it is connected to the bathroom light, light is turned off but fan goes continuiously??????
Then it is not connected to the light switch as you think. This could be a dangerous situation, and you should have an experienced electrician look at it.
Mar 02, 2010 | HP Extractor Fan Kit 110V Rack Mount Fan
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
