Question about HP Color LaserJet 2600n Printer
I get a an error 55.1 " turn off and on??? I t was working just fine this morning. Need a little help
    President:
  • HP Master
  • 1,314 Answers
From the service manual:
55.1 Error: DC controller error. The device has experienced an internal hardware error.
Solution:
1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the device on.
3. Check the engine (DCC) firmware version. Update if needed. Replace the DCC (DC Controller) if a firmware upgrade does not resolve the issue.
Posted on Jun 17, 2009
Stihl BG 55 Blower Starter Rope Won't Pull.
indications are that there is insufficient oil in the mix and the ring has failed and jammed
you may have to pull it right down or simply junk it
if it has been discontinued then parts may also be scarce
Sep 24, 2016 | Stihl Bg 55
Purple screen
Sustain board fault. Contact any service technician. It is a skilled work to locate the exact faulty sustain board. Gopakumar Gopalan Google
Mar 09, 2014 | Fujitsu P55XTA51US 55 in. HDTV Plasma...
Tv will not turn on the light on the front just flashes. It worked fine in the morning came home from work and can't get it to work. I unplugged it figuring it would reset.
If you still have the manual, look in troubleshooting for "Blinking LED" this is a diagnostic tool used to help determine the problem. It could be as simple as a lamp or it could be the power supply.
This is the link to your manual if you don't have it.
http://www.fixya.com/support/p203662-toshiba_55h70_55_in_rear_projection/manual-5605#
Hope this helps
Jul 11, 2011 | Toshiba 55H70 55" Rear Projection...
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
Started up this morning fine went and did not start at all later.
remove and, clean your battery cable clamps then retighten and, test.
If your battery is too discharged "jump" it using jumper cables and, another car.
Apr 25, 2010 | 1996 Chrysler Cirrus
I have a samsung sp43h3ht it will not turn on it
hey i have the same problem have u found the fault
Oct 24, 2009 | Samsung SP55W3HF 55" Television
Stoves oven genus 900 error codes
Hi phill6x6...try turning on the oven by the main button, and press and hold button 7 until it beeps. Hope this helps you, and a few others!!
Nov 18, 2008 | Stoves 720EF Electric Double Oven
Icemaker won't freeze - Samsung RS2578SH
Did you ever get any advice for this problem? Please repost if not.
Oct 07, 2006 | Samsung RS2578BB Side by Side Refrigerator
HP Color LaserJet 2600n Printer Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
