Question about Elna Sewing Machines
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Do not have manual
  • Elna Master
  • 1,134 Answers
The Elnita is the entry level model in the Air Electronic compact series, there is no reverse lever or button. Instead, you stop stitching, turn the stitch length dial back to zero, then keep turning into "negative" area, it should look like this "-- --- ---- -----" on the dial. Turn it back about half way into the negative area and you will get a reverse stitch of about 2.5 or so. Do your reversing stitches, then stop and turn the dial back to original forwards stitch location, and continue sewing.
Posted on Sep 24, 2017
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Posted on Apr 10, 2014
SOURCE:
  • 155 Answers
SOURCE: I need to thread an
Needle Faces Where?
I Need to Tighten the Tension....
Changing a Needle
Need Help
Basic Questions-
Bobbin Assembly Popped Out!
Do You Think My Machine is Fixable?
How to Change a Broken Needle
Needle Bar Adjustment
Oiling an Elna 3007
Getting the Timing Belt Off?
What Size Needles for My Machine?
How to Oil my Machine?
Where to Oil??
Stitch Length Knob Woes
Can't Seem to Put the Bobbin in Correctly
Timing Belt Tension
Adjustments
Running Very Slow-
Oiling Points on Singer 257
Oiling My Singer Touch & Sew
Singer 457
Featherweight Case Odor
Brother XL2010 Q's
Does My Machine Have More Than One Belt?
Cannot Seem To Adjust the Tension
What to Do About a Gumming Up Needle
How Tighten My Bobbin Tension, Please
Is it Covered Under Warranty?
Proper Threading Instructions?
Just a Foot Pedal?
Simple Threading Instructions for a 1036
Threading a Singer 600
Replacing a Blade on a Johnson Ruffler
Changing the Needle
Lubricating a Singer 1036
Thread Balling Underneath
Warranty Info
Machine Covered in Hardened Oil
Spindle Stuck?
Do Motors Die?
Singer 457
Brother Sewing Machine
Servicing My Machine-
Belt Replacement
Lubricating My Sewing Machine
check out this thanks.
Posted on Oct 26, 2008
SOURCE: my elna SU air electronic model 68 is not working
I have a Elna air electronic No 69 I am having trouble with the tension . How can I fix this.
Posted on Jul 20, 2009
rickead1
  • 1998 Answers
SOURCE: I need a manual.
well you could get the manual from this site http://safemanuals.com/user-guide-instructions-owner-manual/ELNA/6005-HEIRLOOM-EDITION-_M but i would go with this one instead its a bit easyier to get http://www.tradebit.com/filedetail.php/26965882-elna-6005-sewing-manual-instruction-manual if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Posted on Dec 15, 2010
Tally Girl
  • 1134 Answers
SOURCE: how to thread the bobin on a elna air electronic
I assume you mean when you wind a bobbin full of thread??
You take the end of thread from your spool through the tension device or an eyelet on top of the machine, then back to the bobbin on the bobbin winder and thread the loose end through a top hole on the bobbin. Click the bobbin in against the stop and press on the pressure foot to start to wind. Hold the top thread for a bit as the bobbin starts to fill and then once it has been covered by a row or two of thread, stop and cut of the loose end from top of the bobbin. Now continue to wind the bobbin until it cuts out as it fills against the stopper. Nudge the thread with a finger tip as it spools onto the bobbin to help get the bobbin filled top and bottom and not just in the middle. (bit like when you coil the garden hose onto the reel, it always wants to go in the middile only and then jams up LOL).
Also a really good idea to place your scissors handle into the top of the thread spool to slow/control it as the thread reels off it. This helps give an even tension on the thread going onto the bobbin which really helps with stitch quality later.
Posted on Mar 03, 2011
Tally Girl
  • 1134 Answers
SOURCE: I have a old Elna
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Posted on Mar 07, 2011
How do you thread an elnita 200 ?
How to thread and use Elna SU sewing machine
Athough most likely not your model, threading instructions are pretty much the same for the majority of machines except in extreme cases. Of course, a manual for your machine would also be helpful, even just for the maintenance and use instructions.
Elna Elnita 200
Elna 240
Instruction Manual Elna Elnita 200
Tip: ALWAYS RAISE the presser foot when threading the top thread. Always start out with a brand new needle (and change it at least every 8 hours of sewing time).
Dec 04, 2017 | Sewing Machines
How do i fix a n elna su that will not stop after releasing the foot pedal
I'm guessing this is an Elna air electronic SU? If yes, then the problem is with the diagram inside the right side of the machine where your air control foot pedal tube feeds in. I havent' done this repair myself, I took mine to my favourite sewing machine technician. But if you are technically able, try joining the Yahoo Group called Elna Heirlooms, and then go through the threads there, there's been discussion on this repair before.
Dec 21, 2014 | Elna Sewing Machines
Manuel elna su air electronic
I have a manual for the SU Air Electronic if you are still looking? you can email me on tallygirl98 at yahoo dot com and I'll send you a scan
Jun 23, 2014 | Elna 2007 Mechanical Sewing Machine
What make of walking foot would fit my Elna su air electronic sewing machine, thankyou
You need a low shank style walking foot. Even back in the 80's when your SU air electronic was new, the walking foot sold by Elna was an after market one, and not made by Tavaro. Same with the ruffler attachment, it was after market and actually fitted quite a few makes of machine.
I would just ask the dealer/shop if they will refund your money if you find it doesn't work just in case.
There is a low shank one on sewingpartsonline.com
http://www.sewingpartsonline.com/walking-foot-low-shank-p60444.aspx and they list the SU as compatible with it.
Take off the foot holder on your mache, and you need to fit the little open ended arm over the needle bar and the foot bracket onto the foot with your machine's regular thumb screw. The up and down movement of the needle bar operates the walking foot.
Jun 25, 2011 | Elna 2007 Mechanical Sewing Machine
My elna SU air electronic model 68 is not working I need to fix it. How can I find a repair expert.
Jul 13, 2009 | Elna Sewing Machines
Sewing Machines Logo
298 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Elation Relation
Level 1 Expert
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
