Question about Kenmore Dishwashers
My water spinner burnt to the heater coil - Kenmore Dishwashers
    Scholar:
  • 85 Answers
It was the piece at the top of the tub wasnt it?it fell off and got hung under the element didnt it? mine did the same thing. well it burned a spot on the tub sears has that piece pretty cheap. I didnt worry but later the tub material cracked at that point where it burned and I put RTV silicone on it. the leak kept coming back. the washer has a lifetime warranty on the tub from cracking but if it is past its normal warranty period the labor will cost as much as a new dishwasher.
if it leaks if I had it to do over. I would drill holes at the ends of each crackline and then seal with RTV silicone. and maybe the cracks will stop.
Posted on Jun 17, 2009
Why doesn't the machine wash?
Firstly check power supply machine is getting or not. If your machine is not spinning the rotor shaft has been Jammed or the Machine Motor coil is burnt away due to this machine motor rotor is not spinning...... Check the Spinner is it jam, if it doesnt work call electrician to check the motor
Oct 30, 2016 | Washing Machines
My heater doesn't work on my 06 buick rainier
A few things to check would be your fuse, refer to your manual to see which fuse controls the heater and if your fuse is good your heater coils for your heater might be burnt out. Or maybe just a loose connection to the heater coil.
Nov 08, 2014 | Cars & Trucks
I've got mould in the little squares of my salad spinner. What's the best way to clean it?
I'm guessing that your salad spinner is made of plastic. If you don't have a dishwasher with a hot water option, I would fill your sink with very hot soapy water and let it soak until the water cools. By then, most of the mold should have come off and you can simply rinse it.
Jul 11, 2013 | Home
The refrigerator stays at 47 degrees but the bottom compartments freeze
You have a defrost problem. A blockage of frost in the freezer prevents air flow over the cooling coils there, allowing very cold air to migrate back into the bottom of the refrigerator section. Unload the freezer and remove the back wall, melt the frost off the coils with a hair blower, and check to see if the defrost heater at the bottom of the coils is burnt out. If heater is OK, replace the 1.5 inch long white thermistor located at the very top of the cooling coils.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Icey coils,replaced bunrt defrost heater coils still ice up
Replace defrost timer and defrost thermostat.
May 13, 2009 | GE Refrigerators
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
BISSELL 1699 :WATER PUMPS THRU HOSE BUT NOT TO FLOOR NOZZLES
Did you blew thru the heater with both hoses off of it? If you did and it was clear, could be the pump, it is just working weakly. Is the top cover flush with the base in the back? If it has broken loose and has risen up, then it won't work. Here is a diagram that may help:
Aug 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
