Question about Aspen Refrigerators
About a week ago, ice making slowed way down.
Does not make enough ice. water flow is OK to refrigerator. water flow from dispenser is about half of what it was. It makes one or two trays a day. checked water flow by detaching from refrig. blew air through water line into the refrigerator. Reset the internal water filter. Replace light came on momentarily. Item is year old. Turned ice maker off and then on.
Changed the water filter. cost $43 for a new one. crazy.
Posted on Jun 17, 2009
Slow water flow from water dispenser
Check water supply make sure you have ample water and not a kinked connection from supply. It is a common failure on Amana to have a defective Filter/Head assembly.
Mar 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Purchased a GE Profile bottom freezer April 08. Has indoor water dispenser. Changed the water filter 60 days ago. Since then the amount of cold water dispensed has slowly decreased to a trickle. There...
Disconnect the water line where it comes out of the water inlet valve and see how the flow is when you try the dispenser. Disconntct the water line at the bottom of the freezer door where it goes into the door. If it flows good here it may be freezing in the door. Open the door till it thaws.
If it's good at the inlet valve and slow at the door, some models have a way to put a plug in and bypass the filter.
Aug 14, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Low flow from water dispenser
hi, this can be because of the filter. when the water is flowing threw the filter, it is sent threw many channels inside the filter before it reaches the dispenser. this slows it down a bit. this is quite normal but, if it's slowed down to a dribble, i suspect a water valve malfunction or you may need to change the filter.
Mar 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water no ice
Dear Customer
Please perform the following checks
Refrigerator starts and stops frequently :
Refrigerator or freezer is not cold enough :
Please rate this,Thank u
Dec 18, 2008 | GE GSS20IEP Side by Side Refrigerator
GE monogram side by side no ice water dispensed not cold
To actuate the ice maker pull the arm down and it is in the on position.
The water is actually cooled in the refrigerator section. However it is not designed for a continuous flow. It takes time for the heat to be removed between each water draw.
If your refrigerator temperature is not cold enough it will affect the water temperature also. Check the refrigerator compartment temperature with a thermometer.
May 16, 2008 | GE PSS26MGS Side by Side Refrigerator
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
184 people viewed this question
Top Aspen Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you an Aspen Refrigerator Expert? Answer questions, earn points and help others
