Question about Maytag MBB1956GES Bottom Freezer Refrigerator
May tag mbb 1956 ges refigerator section not working frost built up in freezer though.
  • 159 Answers
The gas level are low in the system
Posted on Jun 17, 2009
Freezer works but refigerator won't get cold
IF YOU HAVE ALOT OF FROST ON THE BACK PANEL OF THE FREEZER IT IS A DEFROST T-STAT THAT CAN BE BAD IF THERE IS NO FROST FELL UP IN THE LEFT UPPER CORN OF THE FRIG SIDE SEE IF YOU CAN FILL THE AIR COMING OUT OF IT
Nov 01, 2012 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
Refigerator compartment not cooling...frost built up on cooling coils in freezer
You need to replace the defrost timer and defrost heater element.
Aug 10, 2011 | Whirlpool Refrigerators
Freezer is freezing fridge is warmer than usual does the dial indicating coldness from 1 to 2 apply to the freezer, refrigerator or both? have cleaned condenser on back of refrigerator - it was not really...
Usually, the freezer knob just adjusts the airflow from the freezer to the freshfood section. The refigerator control turns the unit on and controls temperature. When unit is running, do you hear the fan running in the freezer? The fan forces air to the refigerator section. If not, probably bad fan motor. If it is, do you see frost build up on the back wall of freezer section? If so this would indicate a defrost problem, ice build up on evaperator blocking airflow to refrigerator section. You cleaned the condenser, Was the condenser fan running? Defrost causes. Defrost thermostat, heater,defrost timer. Good luck.
Mar 31, 2011 | Whirlpool Refrigerators
Ice built up in the frost free freezer section
It sounds like the freezer fan(evaporator) is wearing out. This problem is very hard to diagnose because the fan spins but no fast enough to circulated the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Freezers
Frigidaire Refigerator
TEMP FIX i found remove hinge cover top of left door and unplug the Icemaker and fridge will run again havent figured out the problem with icemaker yet though
Feb 18, 2008 | Refrigerators
Freezer works frige dont
check for frost in freezer section. If frosted up your air flow is being blocked. Must thaw and determine why it is not defrosting
Jan 05, 2008 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Freezer works; fridge side doesn't
First thing to check is look and see if there is  thick frost build up on the back lower panel inside the freezer?  If not there must be a problem in the damper (vent).  Let me know what you find so I can help.
Oct 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag MBB1956GES Bottom Freezer Refrigerator Logo
188 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
