Question about PC Desktops
Reformat HP pc hard drive.
Hi! My computer's been acting up for a while, so i got fed up and decided to wipe the drive and take it back to factory mode maybe the virus or whatever software issues it has will kinda reset. I didn't satisfactorily wipe the drive because even though i've lost almost all my data files (music etc) it still has "ghost programs." There are icons that won't link correctly. Even worse, it's norton antivirus is faulty now, and everytime i boot, a screen with a foreign launguage pops up and i have to click ok for it to go away. I cant get my hands on any free antivirus currently because my dial up takes forever so i want to reformat it again. Can someone tell me how to do it right this time? i have an xp o.s. but cant get the model number of the p.c.
  • 83 Answers
Re: Reformat HP pc hard drive.
1. Start your computer to Safe Mode with Command Prompt.
NOTE: You must log on as an administrator or a user that has administrator rights.
2. At the command prompt, type cd\, and then press ENTER.
3. Type cd\windows\system32, and then press ENTER.
4. Type osuninst.exe, and then press ENTER.
5. Follow the instructions on the screen to begin uninstalling Windows XP from your computer to restore the previous operating system
6.In DOS mode type FORMAT C:\ it will ask if you want to type Y for yes and then RE install windows after the wipe
Posted on Nov 01, 2007
  • 127 Answers
To perform a clean install of your XP. follow this steps.
1.    Start your computer from the Windows XP CD-ROM. To do this, insert the Windows XP CD-ROM into your CD drive or DVD drive, and then restart your computer.
2.    When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD-ROM.
3.    At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4.    When you see the End-User License Agreement, press F8.
5.    Follow the instructions on the screen to select and format a partition where you want to install Windows XP. This would be your c:\ drive
note: when formating the drive do not choose the quick format option.
6.    Follow the instructions on the screen to complete Windows XP Setup.
0 characters
3 Points
Hello, I just bought a HP Pavilion P6000 series. It was a display model. After getting home I noticed I cant log into the main hard drive with admin rights with out a password. The store set a passcode...
Hi, I would contact the store and ask them what they set their password to. Without a restore or windows disk you won't be able to reset it to factory condition or reformat and reinstall windows. They should be able to give you the password and from there you can get in and change the password etc.
Thank you,
Jan 07, 2011 | HP A6620F PAVILION A6620F DESKTOP PC
I just want to restore to factory defaults
The best way to reset your Laptop to Factory Default is to reformat it. Depending on which version of Windows you have this will create a directory in your Hard Drive called Windows.old, or depending on whether or not you deleted the partition, it will erase everything. You'll want to back up your hard drive if you have anything worth saving.
Beyond that, pop in your recovery disk, or if you don't have it, put in your Windows disk, then restart your computer. When your computer is booting up, head into the BIOS and set your computer to boot from your DVD Drive. If you aren't sure how to do this then reformatting is probably not a good idea. Once you've booted from the disk, just follow the instructions to reformat.
Dec 27, 2010 | Acer AX1200-U1520A PC Desktop
HP Pavillion m7750n has already had the hard drive replaced almost two years ago. The computer will be four in January. It stopped working about five months ago and I finally decided I had enough time to...
Either the disk is faulty or the the boot block is corrupted. If you have the operating system CD, you can try to reload it. Doing so will wipe out anything you have on the drive. If it reloads, you will be back in business. It the disk is faulty, the OS will not load.
You may want to take this computer into the Big Box store and have it evaluated before youtry to do this repair.
Thanks for your interest in
Nov 23, 2010 | HP Pavilion m7750n PC Desktop
Recent upgrade of 320gb sata hard drive and additional 2gb of DDR2 400mhz memory.Installed and configured by dell to my dimension 5150 has not solved my problem of.CPU usage when on broadband of 70-80% and...
Have you tried to reformat or wipe out your computer? If not I would go ahead and do this with a clean installation of the OS. If it continues to act up , then you definitely have a hardware issue. Please post back after you do this or have done this already.
Feb 18, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
In my experience, your computer's hard drive might be fried. I took a couple computer architecture classes and this seems to be the most reasonable answer. if I were you, i would find a computer technician just to be sure. Hope this helps, good luck
here are a few websites that might help
Jan 01, 2010 | HP Pavilion a1610n PC Desktop
Installing XP
DId you "Wipe" the hard drive or just "Format" it? There is a big difference?
Sep 17, 2009 | HP Pavilion a705w PC Desktop
I want to format my v2000 compaq presario so how can i do it
Your computer almost certainly came with "system restore" discs or a reinstallable copy of Windows.
The first will wipe out your hard drive so it looks just the way it did when it came out of the factory. The second will give you an option to reformat during the installation process.
Either option will wipe out all of the Windows updates you've installed, just as it will wipe out all of your critical documents, pictures, music and everything else. Make backup copies of everything you might possibly want before proceeding.
Dec 07, 2008 | PC Desktops
Wiped all files
Formatting a drive is not a complete loss. When you format a drive you wipe out the File Allocation Table (Hard Drive Index) and the data is mostly still in tact as long as nothing writes to the drive after the format.
The problem here is that you didn't just format your drive. You ran the system restore which means you formatted your drive, then wrote the factory defaults to your drive completely destroyed the data on your drive.
I can't offer your a solution for your data. I can offer you a solution that will prevent this from happening in the future.
Pick up an external USP hard drive. They have come down considerably in price now a days and for Around 70 to 200 dollars you can get a real nice drive. You want something between 200GB to 1TB.
Put your files on that external drive. If your computer blows up and you have to reformat, your files will be there after you recover your PC and replug in your drive.
Jun 09, 2008 | Acer Aspire™ T180 PC Desktop
Wiping a hard drive
The following are the instructions to wipe out the hard drive.
Turn off the system.
Then turn on the system and immediately when you see the Dell logo, press & hold the control key & f11(function key 11).
It will initiate the pc restore option in the Dell system.
PC Restore will restore the system to the factory installed conditions(OS,Drivers & applicatiopn came with the computer).
If no pc restoe available try the softwares
Good Luck.
Live, Love, Laugh.
May 05, 2008 | Dell Dimension 3000 PC Desktop
PC Desktops Logo
442 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
