I have model LG0332DS0 (stackable dryer). The heat comes on but the drum doesn't move. Can you help me with this?
SOURCE: No Heat on a whirlpool
if ignitor not coming on could be flame sensor mounted on side of burner housing or ignitor ..if ignitor glowing but burner no lighting replace both solenoids bad connections interally on solenoids..also if ignitor not glowing possible small white thermal fuse open.. sensor and fuse can be jumped across to confirm ..
SOURCE: Whirlpool Ultimate Care II - Gas Dryer - Drum Won't Spin
If you are handy with tools, try to remove the back panel and feel the belt that should surround the drum. If access is that limited, try to turn the dryer on its side and you can get to the motor from the bottom. But like the guy said before, call a pro if you can't do any of this.
SOURCE: dryer turns but no heat and knob doesn't move
Check the switch on the motor. It may have failed, or has a wire/terminal broken/disconnected. It is a multi-contact switch. both sections must click. Could also be mechanically loose on the motor and therefore just not getting fully activated.
Hope this is helpful.
SOURCE: Gas dryer won't heat after a move.
Make sure the vent is not blocked. Run the dryer and feel for a strong air flow at the vent outside. The most likely cause is flexible vent hose used on the dryer is squeezed behind the dryer, blocking air flow. Don't use flex hose. You may have a lot of built up lint in the dryer vent pipes also, which would need to be cleaned out. Also, make sure you are still using the same type of gas. (natural vs. LP) If different, dryer would need to be converted for proper opperation.
SOURCE: i have just bought an
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
