It just started happening where my honda civic with start fine, but then when i push the petal its super slow and wont gon anywhere, the rpms spike to get it going to 40 mph and after that rpms go to like 3-6
SOURCE: 1997 Honda Civic EX (automatic) jerks while accelerating?
Check your wires, plugs and coils. I think it is an ignition problem myself. Something is breaking down under a load. My guess would be a bad coil or wire, the hard starting could be a symtem of this also, As I first read your description I was thinking maybe a leaking fuel injector or faulty fuel injector, but I believe it is in the ignition system. I hope this Helps! Merry Christmas!
SOURCE: 2002 Civic EX wont accelerate
It sounds like a problem with the transmission. The creaking could be a bad power steering pump or simply a dry/leaking rack & pinion.
SOURCE: 1991 honda civic brake light stays on need to push brake pedal to
Sounds like you might have a caliper that is stuck and is not fully disengaging. If it is in the rear then you may have a bad rear caliper. Twoo things you can try. One is to crawl under the ca and adjust the tension two nuts on the emergency brake line. If that does not resolve the problem then remove the back tire and try to spin the drum or rotor whichever you may have. If it does not spin then try adjusting the e brake cable more if it still does not respond then you need to do a brake rebuild. Also does it pull while it is dragging? If it is then you will need to rebuild the brakes no matter what.
SOURCE: 1996 honda civic lx Automatic transmission startting to slip
try having the transmission filter and fluid changed.
SOURCE: my 98 honda civic Lx wont shift into gear
check your shift linkages if the bushing is worn out you may have problems shifting or it could be a bad transmission
my dad changed the fuel filter i think and still nothing he thought it was clogged but nothing.
he thinks its a fuel problem
