THE LAPTOP DOES NOT BOOT
When I turn on the laptop, it does not boot or it does not display the screen. The screen stays black. When I unplug it, the power light still lit for a while.
  • 85 Answers
Its a sensitive problem, 1st remove your CD-Rom drive then start your laptop, if consist then open the skrews of hard disk portion and remove it also then open your laptop it will display the screen.
otherwise contact your hardware doctor.
shafky
Posted on Jun 17, 2009
Please I hope someone can help me. The laptop is stuck on the reboot and select proper boot device screen.. i can get to the bios though
unplug your laptop, remove the battery and wait for three minutes. then install back your battery and power on. right after you power on your laptop press shift key together with f9. release the keys when the laptop begin to boot. follow the instruction on the display.
Sep 04, 2015 | ASUS X551MA-DS21Q 15.6" Notebook - Intel...
My Medion laptop won't boot windows; black screen
Unplug, remove battery, Remove and reseat Memory Mods, try to reboot. If no, Remove HDD and test, replace if necessary. Has their been any damage? Dropped?
Feb 02, 2013 | Computers & Internet
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
When I turn on my laptop pc every couple days a black screen will come up and the laptop stops processing. Why? How to fix it?
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
Dec 25, 2012 | Acer Computers & Internet
My FUJITSU SIEMENS AMILO PA 1538 screen comes black ? HELP
Try connecting the laptop to an external monitor and see if all is working Ok with that, if it is, then you may need to get the laptop display serviced - if it does the same on the external display, then try booting the laptop from a CD or DVD such as an OS install CD (Windows or Linux) or a boot utility CD such as Hiren's Boot CD - this will allow you to test whether the problem lays with your installed operating system or with the hardware. . . .
Note: do not go any further than the initial displays if using an OS install CD unless you are using a Linux Live boot CD which will not destroy your installed operating system. . . .See http://www.hirensbootcd.org/ to download a copy of Hiren's Boot CD to burn to a CD. . . .See http://www.ubuntu.com/download/ubuntu/download to download a copy of a Ubuntu (Linux) Live CD.
Dec 17, 2011 | Computers & Internet
It turns on and everything but the screen just stay black..............can anyone help me
The first thing to try is to plug in an external monitor to the laptop while the laptop is off, then turn it on and see if the screen comes on. If the screen comes on and the laptop boots like normal then your LCD is bad, if the screen never comes up and you still think your laptop is booting in the background (for instance you can hear the start up sound and see the hard drive working during boot) then the video card on the laptop will be bad.
If the laptop only seems to turn on, but it appears there is no sign of it booting then there will be a different issue. At that point the first thing to do is remove anything that is not needed to boot the laptop. Remove the hard drive, the cd-rom drive and any extra memory trying the memory one at a time if there is more then one. All of these should be easy to remove and under access panels on the bottom of the laptop. Once these are removed try to boot the laptop, if you see the screen come on then that means something you removed is bad, you can put everything back one at a time trying the laptop after each thing you put back until you find the culprit. However if the laptop still will not boot then either the memory or the motherboard is bad.
Mar 11, 2011 | Computers & Internet
My computer will not boot up Acer 5050 all the lights com on but it never boots the screen stays black. it will not turn off unless you remove the battery.
If you have a VGA cable and a monitor, attempt to plug this into a monitor to verify that the laptop will not boot into your OS (Windows generally). If it does end up booting into your OS, then it sounds like your LCD has died or become unplugged inside the laptop.
Nov 25, 2009 | Acer Aspire 5050-3242 Notebook
I have a Gateway laptop MX8738, Windows Vista, Dual core. My issue. I always plug my computer into outlet. Do my work. Close down laptop, and unplug from wall. Then about 3 hrs later I plugged in laptop,...
Hi there.
Take the battery out and try to boot on AC power only, if it boots up, turn it back off and reinsert the battery and try to boot again.
If it still suffers from the same symptoms please post back for more advice.
Good luck
Jun 15, 2009 | Gateway MX8738 Notebook
Screen stays black when booting up on Gateway laptop
there is a inverter in lcd that makes shinely, white .
it looks like inverter issue. need to get service.
May 29, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
145 people viewed this question
Alun Cox
David Payne
David Payne
