Question about Sony Playstation 3 (PS3) Console
Can't get network connection to work.
Fails connection test when it gets to IP adress, when i go to look at the IP adress it isn't there.
  • Sony Master
  • 32,281 Answers
Are you trying to connect to the Internet using a wireless router or vai a network cable?
Have you got an Internet Service Provider and does your computer have trouble connecting to the Internet?
Posted on Jun 17, 2009
SOURCE:
I P ADRESS FOR MIVAR TV
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit IP-details.com and get the IP.
Mar 01, 2014 | ip-adress.com
I cant get my ne10 to connect to wifi
Try to reboot BOTH devices, remove power from Both devices and reboot. I'm not sure what a ne10 is? The "aquiring network adress" is it's try to aquire the IP address. If you power everthing down it should reset everything. You question isn't very clear. I don't know what "IT' is? "when i try to connect "it" to my web cube "it" just says aquiring network adress how do i get "it" to work properly please"?
Nov 13, 2012 | Samsung NC10-14GW Notebook
Is their anyway i can stop the lagging when using cricket 3g mode
how did u get it to connect to your ps3??? i get a signal of 100% then when i go to test the network, the ip adress works, then the rest of the test fails :-(
Jan 26, 2010 | Sony Playstation 3 (PS3) Console
I recieve error that I can't get a Ip adress. WEP security password goes to the router but no Ip adress is making it back . I've tried loading a static IP adress, using another unsecured network. resetting...
Try using the HEX password instead of the ascii passphrase - also try to reset your AP temporarily in order to test the connection without ANY wireless security - if that doesn't connect, then the problem probably lies in the wireless router itself.
Oct 20, 2009 | Microsoft Xbox 360 Elite Console
Ip adress failed
u should try ringing ur internet server and u dont connect it to ur laptop u connect it to ur modem and router and btw for some reason xbox live doesnt work for everyone it weird but no one knows why
May 09, 2009 | Microsoft Xbox 360 Elite Console
Router wont let ps3 have ip adress
you need to open a incoming port for the ps3 on your router all you have to do is use the computer to go to your router settings then use whatever ip the ps3 is using and open a port for that ip address that should work but i dont have a ps3 so i dont know you could try that
May 09, 2009 | Computers & Internet
Cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
May 07, 2009 | Nintendo Pokemon Pearl Version for DS
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Ps3
wired conection , connection test fails obtain ip adress connect but connection internet failed.
Oct 07, 2008 | Sony Playstation 3 (PS3) Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
91 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
