Question about Microsoft Xbox 360 Console
No connection I need get some tip about my problem. I need a connection on line, I'm new in this area.
  • 79 Answers
Re: no connection
I don't really understand what you're asking here, how to get online with your 360? You'd need a broadband connection of course, otherwise the question isn't very clear, apologies if not very helpful but the question doesn't really explain your situation!
Posted on Nov 25, 2007
0 characters
3 Points
I need to change my password in PSN becasue of the new update, but it is saying that i need to check my e-mail, but i did not get one. Now it is saying that an error has occurred in the server. Please help
Your issue is being experienced by a ton of users, I have written a tip to help solve this issue. >PSN Password Tip
The error you are getting is because the PSN isn't up and running in all areas of the world yet, they are working fast to get it up and running!
May 15, 2011 | Sony Playstation 3 (PS3) Console
My xbox 360 keeps saying reading the open tray when ever i put a game in it. I have tried different game same response.
It looks like you need a new cd drive. Contact microsoft if you still have warranty. If you don't have warranty take it to an EB Games or Gamestop and they will repair it for a charge.
Nov 30, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 controllers they blink a green light and won't do anything...whats the problem?
Everyone knew that Xbox 360 had it famous 3 Red light of death but Sony Ps3 had it too. They called it as Red, Yellow, Green Light of Death. Although PS3 is the new generation of cutting edge high end technology console, it can still have problems like this common one where it flashes green lights instead of working properly.
It really annoying and frustrated if you face this problem and feel lost on where you actually can start to looking into it.Keep reading of this hub and share with you some basic troubleshooting tips that may help you to solve PS3 blinking problem and get your PS3 console work again.
You actually can start to look into the PS3 light flashing problem yourself, at least you can narrow down the error or can get your console work again on those fault alarm.
What you can do:
Tips 1 - Restart your PS3 console by turn it off and on it back. This to ensure a soft rest to your PS3 memory board. This can eliminate blinking problem that cause by in-proper shout down and memory interrupted.
Tips 2 - If tips 1 not working, try to check whether all the cable are well connected to the console with the power code. Make sure those cable in good shape, none of them are loose or damaged.
Tips 3 - If above tips not help, you need to unplug all those cables connect to your console and plug them back on. This way to ensure none of the cables are not connected.
Tips 4 - This could the final tips if none of above working. You need to take the hard drive out for 10 minutes and let it cycle its memory. Then re-hook it and try it again.
Above tips able help you to eliminate those common PS3 light flashing problem, but you may ask what else if those tips not work although you try all them out?
Aug 20, 2010 | Microsoft Xbox 360 Console
Can not get psp to connect to wireless router
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Steps Turn on your PSP.
Enable wifi by flipping the WLAN switch to the on position.
Select network setup from main menu, select network settings (press "X").
Select infrastructure mode.
Create a new connection.
Select scan to look for your WiFi network.
otherwise if you know all of your network settings, you can do it maually
Select your wifi networks SSID.
Enter your security settings(if applicable)(WEP, WEP TKIP, Shared Key).
Select "easy" in configure network settings to obtain ip address.
Confirm the settings.
Test the connection.
Go back to the main menu, select the broswer & enter a web address ( etc.). Your PSP's internet is ready to be surfed out wirelessly.
the psp, unless you have a hack installed, will not be able to browse sites such as youtube, or facebook, or twitter because they require flash/java/enhanced memory[this is not the memory stick]it can however use facebook mobile or myspace mobile by typing in m.facebook/ -- Tips:
  • You may have to do this every time you are in a new area or surrounding that has wifi hotspots
  • Go to for tips, tricks and hacks.
  • Go to your favorite cheat code website for cheat codes.
Things You'll Need
  • Sony PSP
  • Internet
  • Wireless router
Jun 11, 2010 | Sony PlayStation Portable (PSP) Console
I cannot connect on line with my PS3
Call (800-345-7669)
Sony Network is experiencing sporadic outages in certain areas today.
It may be a scheduled system upgrade or maintenance - but be assured you are not the only one facing this issue.
No UP time has been announced by Sony - they are working to get the system up and running as soon as possible.
The problem is not on your end.
Keep trying to connect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Action replay problem
Your AR Cartridge probably needs a cleaning. Use some rubbing alcohol and a q-tip and rub it on the pins of the AR Cartridge. Then use a dry q-tip to dry the rubbing alchohol. If that doesn't work then you should probably buy a new AR.
Mar 01, 2009 | Nintendo DS Lite Console
Only the Start and Select buttons don't work on my Nes Controller
Take the controller apart and check the wire connections on the controller card. There are many times with a system this old that the wires could be pulled off the board. If the wires are disconnected then you may have to solder them back together. If they look good and are making good contact then check the area where the start and select buttons are. You may need to just clean the area. Use alchol and a small soft bristle brush or a Q-Tip and clean the area and allow it to dry. This should get the buttons to work again.
Feb 25, 2009 | Nintendo NES Console
My x box is not loading any games and only showing the green x on screen and only showing 2 red lines on front panel
The two red lights means overheating. Either let your console cool down; or vacuum the vents on the back of the xbox to get the dust out. For further assistance, call 18004MYXBOX.
Tip: Keep you xbox on a cool ventilated area.
Apr 02, 2008 | Microsoft Xbox 360 Console
Nintendo NES Repair
It's as simple as unscrewing the console by removing all the screws from the bottom. Once inside take off the metal piece over the area where the game is inserted. Once under there you can remove the two screws that hold the 72 pin connector in and pull it out and slip a new one in. Put it back together in reverse.
Mar 26, 2008 | Nintendo NES Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
