Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
My seagate 250 GB hard disk is not being detected, no lights, pls help me!!
    Scholar:
  • 94 Answers
First, try plugging it in to another usb slot.
If it still does not work, plug in another device to the same usb slot. If it does not work also, there is a problem with your usb slot, and you can buy an extra usb slot.
or, if the other device works, try unplugging and taking out all the power supply for your desktop/laptop. Then, after 20 minutes, plug them back in and then plug in your hard drive, then turn on your computer.
Hope this helps, leave a comment on what happened ^_^
Posted on Jun 17, 2009
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a 250 GB Seagate ST3250820SV Hard disk, which got damaged due to excess power supply. I have large amount of data on it. Hard disk is not detected by any of the systems. I am looking for a logic...
A common fix that may work in your case is to remove the TVS diode. Go here and search on TVS diode and read up on it http://forum.hddguru.com
For a PCB try http://www.hdd-parts.com/
Aug 04, 2011 | Seagate SV35 ST3250820SV 250 GB SATA Hard...
How to reformat 250gb seagate freeagent hardrive which can't be detected in my computer and disk management?
make sure the connector of the hard drive is in good condition,if the connector is good ,then the hard drive is crashed
May 24, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My seagate st3250820a has been setup in old pc in dos fat32 mode using device driver and running ok before..now i put my harddisk into new pc has detected 137 mb..can you pls to inform how i fix it to 250...
Please format the disk. You will get the disk space back. If your new pc is running windows NT, 2000, XP, or Vista, while formatting keep the file system NTFS.
Dec 13, 2010 | Seagate Computers & Internet
The hard disk is not working properly now a days some times it is been detected and suddenly disappered , light is also blinking and getting off what to do
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Where can i get the drivers of my seagate external hard disks of 250 GB
The Seagate webite should have them in their support section. Hope this helps.
Dec 21, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Oct 16, 2008 | Intel D845GLLY Motherboard
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
475 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
