Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 stays on for 15-20 minutes then shuts off power standby light flashes green and turns back on. Replaced bulb about 6 months ago with sony bulb. Any ideas. Thanks
  • 668 Answers
The reason this happens the most is because of the lamp being weak. I have not seen anything else cause this problem. You can varify this by turning the set off and wait until it shuts down totally.
with the Sony remote, press the display button, the #5 button,
volume down button, then power button. This puts you into the the factory error code mode. If you see the lamp code with multiple errors and no other errors shown, the lamp is the problem.
Most of Sonys lamps have a aprox life of 3000 hrs. Some last longer and some shorter.
I hope this helps,
Skyassoc
Posted on Jun 17, 2009
    Scholar:
  • 51 Answers
Hi There
While this set is off, does the red standby light flash any error code?
Should be some short flashes followed by one longer flash, before it starts to flash again.
Let us know what the code is.
Good Luck!
Posted on Aug 31, 2014
Sony Wega T.V. won't stay on.
Over Voltage Protection 03. Three blinks of standby light denotes this. The fault is with its main power regulator section circuit. If you wish to get more details about these blinking codes, check this link. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 29, 2013 | Sony Wega KDF E50A10 TV
Kdf-e50a10 green standby light flashes about 20 times.
At that price not a Sony Lamp, do not expect it to last as long as the last lamp did.
Nov 30, 2012 | Televison & Video
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
Why does my sony vega keep turning it self off and back on again
Im guessing it is doiong this about every 30 seconds or so. Im also guessing that when the sound and picture go out, the green standby light flashes until the set comes back on. If this is the case, mine was doing the same thing. I did a bunch of research. I replaced the lamp and the tv is like new, no more problems. The lamp light on the front of the set does not come on because the lamp/bulb is noot burned out all the way. I bought my lamp from www.vanns.com , the best price I found.
Oct 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony Grand Wega KDF-E50A10
The lamp light does not have to flash on this set for it to be the lamp, and most likely it is just that, the lamp. These sets when the lamps get weak they will do exactly what yours is doing.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
Jan 27, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 50 in. LCD HDTV Logo
556 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
